Login Error
Close
5 Home Theater Lighting Design Tips
by DoItYourself Staff
The best way to compliment the picture and sound quality of your home theater setup is by providing perfectly matched home theater lighting. When you are first putting together your home theater you will notice just how many options you have to choose from. Home theater lighting is meant to go with your home theater and not against it and, for that reason, you want a lighting scenario that is darker than normal or has the ability to be dimmed. There are plenty of layouts and designs that you can work with in order to create great home theater lighting. You can add subtlety to your decor or create something that looks like it belongs in a professional movie theater. The article that follows will provide you with several ideas that you can use or expand upon when creating your own home theater lighting.
Three-Way Bulbs
It may seem like a very simple way in which to create home theater lighting but it is a quite brilliant way to make the perfect lighting. Above all that it is also one of the least expensive ways that you can do the lighting for your home theater. You can use normal light fixtures and add the three-way bulbs to them. Install a dimmer light switch in place of the regular switch and you can now adjust the strength of the lighting in the home theater. This will provide you enough light to change DVD discs but also make the room dark enough so that you can enjoy the entertainment.
Light Sconces
The main key to home theater lighting to make the lighting subdued. Using light sconces is not the most expensive solution you can implement but it will certainly do the job that is intended. You can place as many light sconces along the wall that you like. They will provide a dull and subdued lighting that appears to crawl up the wall in a small radius.
Capped Lighting
Many home theaters will also have panels that lessen the vibrations of the sound. These panels create a strong sound without it bouncing off walls to create an echo. Capped lighting is usually place four feet apart between these panels. This type of light does not provide light straight down as they turned to the side and up. Doing this diffuses the light as it is being directed to the walls. This also means that video screen is not reflecting the light.
Rope Lights
This light is easy to install, inexpensive to buy and can be cut to size. If you have stadium seating in your home theater you would use rope lights along the rows. You can also create an aisle with the ropes. Think outside the box and use it as main lighting; running it around the perimeter of the home theater.
Fiber Optics
This is one of the more unique ways to add home theater lighting. Fiber optic lighting can be used nearly anywhere. Add fiber optics to the ceiling to create a starry night or to walls, for example.
 forum activity
