5 Mistakes to Avoid when Installing Recessed Lights in Your Basement
Recessed lights used in a basement or anywhere in a home can create a certain mood or a feeling of increased space in an area. If used directionally they can highlight certain areas or objects in a room and give a very dynamic feel. Installing recessed lights in a room you are building or refinishing is definitely an achievable goal for the do it yourself person but there are certain considerations and problems to avoid while undertaking this task. Here are 5 considerations and mistakes to avoid when installing recessed lights in your basement.
1 - Insulation Rating
When you are placing recessed lighting into a ceiling in a basement you need to consider where the light fixture is placed and what the light fixture is near. Because the recessed lighting actually penetrates into the ceiling or wall, it will often be placed near insulation. This may or may not be the case with your particular install, but it is most certainly something you need to be sure of before you install your lights. If your recessed lights will be placed near insulation you must purchase lights that are IC house rated (rated to be near insulation) to avoid the risk of fire. There are also special covers you can buy for your recessed light fixtures that will keep insulation off of the heated light.
2 - Recessed Light Spacing
A common mistake made when installing recessed lights in a basement is not using proper layout and spacing techniques when installing the lights. It is important that you do not place lights too far apart or too close together when creating your design. There are suggestions for how to space certain sized recessed lights for optimal effect. For 4 inch lights, it is recommended that you space your light fixtures at about 4 feet apart. Accordingly you would place 6 inch lights at 6 feet apart.
3 - Concrete or Plaster Ceilings
Because of the difficulty of installation and the poor lighting effect it seems to have it is not recommended that you install recessed lighting in a plaster ceiling with intricate molding or a concrete ceiling. It is suggested that for these types of ceilings you use a chandelier or table top lighting.
4 - Choose the Correct Bulb
When installing recessed lights in your home there are different types of bulbs that will work better in different types of situations. These different type bulbs are rated in a system that utilizes letters to categorize the type of bulb. For instance, "A" bulbs are incandescent and are best used for general washes of light where as type "R" bulbs are reflective and come equipped with a reflector attached to the back of the bulb itself. Make sure the bulb you buy is right for the job you want it to do.
5 - Know Your Code
Always when undertaking an electrical do it yourself venture it is important to familiarize yourself with the electrical code compliance required in your area. For your safety and the safety of all who are in your home it is important to follow these rules. For instance, there will usually be code that determines how close you can run the wiring for you recessed lights to the outside of your wall so that it is protected from screws and nails. It is important to know all of this information before you install your lighting
