cancel
Job type :
Zip Code :
community forums
comments
5 Modern Bathroom Shower Enclosures
Bathroom shower enclosures were originally intended as a device used to modify bathtub function. This added fixture inside the bathroom is used to contain the steam and water from escaping from the shower or bathtub area. These modifications in the bathroom allow us to continue to enjoy the benefits of the bathtub and shower at the same time.
Purpose and Design of Bathroom Enclosures
Modern bathroom enclosures are generally attached to the floor and wall in the recessed portion of the bathroom. These enclosures are formed with the combination of Plexiglas or tempered glass on a metal frame and are outfitted with a sliding door allowing for the use of either the bathtub (by having one portion of the enclosure opened) or the shower (by having the sliding door closed).
Homeowners are given a broad range of options as far as the designs and styles of bathroom shower enclosures are concerned. You can choose from a myriad of custom-designed and pre-fabricated models made of plastic or glass that comes with or without a metal frame. The selection even allows homeowners to pick one that would fit even the most non-traditional shower and bathtub areas.
The following are the major types of bathroom enclosures that you can seriously consider if you are planning to have one installed inside your bathroom.
Fiberglass Bathroom Shower Enclosures
This category of bathroom shower enclosures is by far the most popular. The shower sectionals and modules can either be made of 100% fiberglass or a combination of fiberglass and polyester resin. This type of shower enclosure is generally considered low-maintenance and comes with a wide range of functionalities.
Tempered-Glass and Acrylic Shower Enclosures
This type of shower enclosure may either be framed or unframed and are generally appropriate for shower surfaces that are curved. These enclosures are sturdy and are easy to maintain. This type of shower enclosure is perfect for walk-in types of shower areas with no doors. It is very sleek in appearance.
Tile Bathroom Shower Enclosures
This is the best option for those who are after a unique and customized appeal for their bathroom showers. One can choose from a wide selection of colors, designs, sizes and shapes. However, you should take into account that this type of bathroom enclosure is prone to mold and mildew, and you will have to do proper sealing and regular maintenance to control this problem.
Glass Block Bathroom Enclosures
This category of bathroom enclosures is the perfect choice for most homeowners. It offers privacy, toughness and aesthetic value, resistance to staining and low maintenance. Expectedly, these bathroom enclosures are the more expensive type. These bathroom shower enclosures will also require the services of a professional for its installation.
Metal Bathroom Shower Enclosures
This type of bathroom enclosures is becoming more popular because of their distinct elegance and toughness. The models that are available are the stainless steel and the copper modules. These enclosures are anti-bacterial, low-maintenance, stain resistant, non-corrosive and mildew proof. There are units that are outfitted with sound attenuation or sound suppressant materials that inhibit the sound from reverberating to the other parts of the home. This is possibly the most modern shower enclosure you can find on the market.
There are many options that you can consider as far as bathroom shower enclosures are concerned. With the broad range of modern choices that are available in the market, you can find the unit that is most appropriate for your needs and is within your budget range.
member comments
Related Articles
Bathroom Planning Offers Space for EveryoneBathroom Planning Offers Space for Everyone
This article explains why the bathroom cannot be overlooked when building or remodeling a home... read more
Add Value to Your Home with a Bathroom Remodel
This article suggests various types of bathroom remodeling projects that will increase the value of... read more
Calculating Bedroom Remodeling Costs
When contemplating a bedroom remodeling project, homeowners often will want to know the basic costs... read more
articles we like
Outdoor Chair
An outdoor chair can be a variety of chairs used in outdoor settings which have... read more
Do It Yourself Gutter Repair Tips
Advice and tips for cleaning and repairing your home's gutters... read more
Facing Foreclosure? Loan Modification to the Resue!Facing Foreclosure? Loan Modification to the Resue!
Millions of Americans are facing foreclosure. If you're behind in your mortgage payments, however, foreclosure... read more
sponsored articles of the day
diy centers
