Login Error
Close
5 Most Common Transmission Problems
by DoItYourself Staff
Transmission problems can result from leakage or from damage to the torque converter, solenoid or internal clutch. Mechanical problems in other parts of the drive train can also lead to transmission problems. Here are the 5 most common transmission problems and their solution.
Low Fluid Level or Leaks
Check and refill your transmission fluid regularly. Refasten and tighten all parts when finished. Leaks can be caused by punctured fluid lines, worn transmission pan gaskets, poorly secured bolts and seals on the transmission pan.
Torque Converter
The torque converter can sustain damage to its needle bearings, making an odd grinding sound when the car is in gear. Inspect the torque converter while the transmission fluid is being changed.
Solenoid
The solenoid manages the transmission fluid flow rate. Check it if there are no evident leaks, but the transmission is not changing gears smoothly.
Clutch
The clutch (inside the torque converter) can jam, and gears will be sluggish when shifting. The car will also shake and the engine temperature may rise. Service is needed immediately.
Other Drive Train Problems
A defective universal joint, signalled by a horrid squeaking sound when you idle the car, may interfere with power reaching the drive wheels. The transmission mounts may be damaged so the gearshift no longer engages correctly.
 forum activity
