5 Must-Have Carpet Installation Tools
Having the right carpet tools can make a big difference on how successful you are when installing carpet. Here are some of the must-have carpet installation tools.
1. Straight Edge
A straight edge is going to be necessary in order to cut the carpet straight. This is critical if you are going to be seaming two pieces of carpet together.
2. Seam Iron
The seam iron is what you are going to use to heat up the seam tape that holds the two pieces of carpet together. This tool holds the edges of the carpet together while you pull it down the edge of the tape.
3. Power Stretcher
The power stretcher is a tool that is going to be used to stretch the carpet across the room. You need to make sure that the carpet has a good stretch on it.
4. Knee kicker
A knee kicker is a small tool that you are going to use to move the edges of the carpet around. This tool has a rubber grip on the bottom that grabs the carpet fibers when you kick it with your knee.
5. Knife
You are also going to need a sharp knife so that you can cut the carpet and the pad cleanly.
