5 Outdoor LED Lighting Wiring Tips
Installing outdoor LED lighting can provide you with functional and aesthetic benefits. Here are a few wiring tips to keep in mind when you install outdoor LED lighting.
Put Safety First
When working on any electrical project outdoors, you need to remember that safety always comes first. You should never consider working under dangerous conditions. For example if it starts to rain or storm, you definitely need to postpone the job. You should also always double check to make sure that the power is turned off while you are working. You should most likely go ahead and wire everything without connecting it to the power source. Then after everything is in place, hook it up and test it.
Plan Your Layout
When you wire outdoor LED lighting, you should work from a plan to achieve the best results. You should draw a diagram of the area and plan out everything in advance. Write down where you plan on installing each component of the outdoor LED lighting. This extra step will often help you avoid making mistakes during the job.
Consider Circuits
When you install your outdoor LED lighting, you need to consider how many lights are on a circuit. The further away a light is from the power source, the less power it will have to work with. Therefore if you get too many lights on one circuit, you can negatively affect the lighting in your outdoor area. Some lights will be bright, while others will be dim. By planning exactly how many lights you want to put on each circuit, you will be able to achieve a more effective installation.
Choose the Most Appropriate Wire
You will also need to make sure that you put special consideration into what type of wire you use for the job. There are many different types of electrical wire on the market. Before installing your LED lights, check the recommended gauge for the job. Using the right gauge will ensure you deliver enough power to all of your lights. It will also make sure you do not overload the circuit by using an inferior wire for the job.
Use Plenty of Lights
When working with outdoor LED lighting, you should allow enough lights for the job. LED lights are over 80 percent efficient and therefore will not use much electricity. This characteristic allows you to install more lights in your outdoor area and improve the overall feel of the space. LED lights can last for over 30 years in some cases, so you should not have to worry about a lot of maintenance by installing more lights.
