Login Error
Close
5 Reasons Why Your Carbon Monoxide Detector Keeps Going Off
by DoItYourself Staff
Having a properly working carbon monoxide detector is the best way to keep you and your family safe from being exposed to the poisonous gas. Carbon monoxide is a tasteless, odorless, and invisible gas that is caused by incomplete combustion of fossil fuels. Having your carbon monoxide detector properly installed 5 feet from the floor, will detects any form of gas that can cause the detector to sound. However, if the alarm does sound, be sure to get everyone in the home to fresh air and call 911 immediately.
Why the Carbon Monoxide Detector will Sound
  • Check the batteries. If they need to be changed, it will definitely trigger the alarm on most models.
  • Check the pilot light on your stove. If the pilot light is off, it can create carbon monoxide, which in turn, will set off the alarms.
  • If you have an attached garage, never let the car run. Doing this can also increase the carbon monoxide in your home.
  • Never barbecue inside your home. Although, that may seem simple enough, many people do barbecue inside their home during the winter. Even with the window open, the smoke could still cause carbon monoxide gases to be trapped within your home, thus causing a heath hazard and triggering the alarms.
  • Never use the stove as a heater. Using a gas stove to heat your house can increase the amount of carbon monoxide gases.
 forum activity
