Login Error
Close
5 Snow Removal Tips for Your Driveway
by DoItYourself Staff
Snow removal is a necessity if you live in an area where snowstorms are common during winter. While the weather may get warmer and the snow may melt, you need to have a few practical options for clearing your driveway. To remove snow, you may use one of the following several methods.
1. Use a Shovel
Using a shovel involves a lot of work, but in the end you can remove all the snow from your driveway and have a clear path for your car. You may ask your family members to help, or if no one is available, you can pay someone for the job. You should find an area to deposit the snow (e.g. the front lawn), as you cannot shovel snow into the road. Put markers in the area where you will deposit the snow, and also mark the edges of your driveway, as these markers will help you when you begin clearing the snow.
2. Use a Snowblower
Using a snowblower is easier than doing all the shoveling on your own and will not break your back. However, you need to invest in this machine and spend at least half an hour out in the cold. Use the snowblower as soon as there are deposits of snow outside, and use the machine regularly so that the snow will not turn into ice. You may have to combine this method with the use of deicers.
3. Use De-Icing Products
If the temperatures fall below zero (Celsius), the snow will turn into ice, and this will be dangerous both for cars and people. Use salt or other deicing chemicals, such as calcium chloride, calcium magnesium acetate or corn based products. Sand may also work well to prevent the freezing of snow. When you choose deicing products, you should consider a few factors, such as the temperature outside, the side effects of these chemicals, and the price. For instance, salt (or sodium chloride) works only at temperatures of down to -9° Celsius (or 15° F). On the other hand, calcium chloride will work at lower temperatures also. Some deicers may damage concrete or leave a slush, so consider these side effects as well when choosing a deicing product.
4. Install Heating Grid
If you experience heavy snowfalls and have long winters, it would make sense to install a heating grid underneath the driveway. The grid will melt the snow when you activate it from indoors. Activate the grid when it starts snowing so that the device will melt the snow as it falls. This will be an investment, but it will pay off, and you will not have to shovel on a daily basis.
5. Use a Plow Service
If none of the above tips work for you or you lack the time to remove the snow from your driveway, you can always use a plow service. Hire a snow plow driver a couple of times during the winter months.
 forum activity
