Login Error
Close
5 Things to Consider Before Getting a Fabric Shower Curtain
by DoItYourself Staff
Do I need a vinyl liner with my fabric shower curtain or not? That's just one of the 5 things you might want to consider when purchasing a fabric shower curtain.
1. Do I Need to Use a Vinyl Liner with My Fabric Curtain?
Mold and mildew feed on soap scum. If your fabric is one that can be easily washed, like nylon, organic cotton or a wash-and-wear fabric, you won't need a liner if you wash your curtain regularly. Heavier fabrics, fabrics that require dry cleaning, brocades and velvets, and fabric with embellishments or non-washable decorative attachments should be used with a vinyl liner.
What Kind of Fabric Should I Use?
Fabric shower curtains come in a wide range of material. Nylon, organic cotton, polyesters and even canvas curtains are wonderful alternatives to vinyl. Many traditional or formal bathroom owners like velvet, brocades and heavy ornate fabric which must be dry-cleaned, not washed. What kind of fabric will you be using, washable or dry cleaned?
How Much Use Will This Curtain Receive in a Week?
If your shower gets a lot of use, it won't get much time to dry thoroughly between uses. Vinyl, or a vinyl liner, may be a better selection. Since soap scum from bathers, not just moisture, is the issue with all curtains, consider how much use and how much soap and water contact your curtain will receive and if the fabric is washable or must be dry-cleaned.
How Often Do I Want to Clean It?
Taking fabric curtains down and replacing them each time you clean them is a labor intensive task. Fabric curtains must generally be washed once a week, while vinly can often be wiped down or washed once a month. Heavier fabrics, like velvets and brocades, may need to be dry-cleaned rather than washed. For many homeowners, when paired with a vinyl, plastic or Ecoprene vinyl, the maintenance is no greater than that of a simple vinyl liner.
Do I Want Low Maintenance, or Better Looks?
Consider how often you plan to wash the curtains, whether you want to match your bathroom decor and if you're willing to install heavier-duty rods, including a rod for a vinyl or plastic curtain liner. Fabric can't just be wiped down, but must be taken down and cleaned. The extra liner and rod can make a fabric shower curtain more labor intensive to put up, take down and clean.
Additional things to consider when selecting fabric shower curtains:
Pros of Fabric Shower Curtains
  • Fabric comes in more designs, colors and weights than vinyl, plastic or Ecoprene vinyl
  • Fabric looks richer, more elegant and plush
  • More and more fabrics (polyesters and cottons) are washable
  • Fabric curtains are designed to be tied back, which makes them look better and hang better
  • Easier to match paint, wallpaper and shower decor with fabric than plastic or vinyl
Cons of Fabric Shower Curtains
  • Fabric is more expensive than vinyl, plastic or Ecoprene vinyl
  • Fabric curtains are heavier and may require additional hardware, and sturdier, permanently installed (not spring loaded) curtain rods
  • Mold and mildew build up quickly on fabric
  • Fabric is a high maintenance choice of shower curtain
  • Fabric can't just be wiped down for cleaning
 forum activity
