5 Things to Look for When Choosing Pool Table Felt
There are a number of things that need to be considered when selecting a pool table felt that will be suitable for your table. It is easy to assume that there will only be one option when it comes to applying felt to a pool table, but there a number of points to take into account. Knowing what points to look for when choosing the felt will help to ensure that you get the best result for your pool table.
1 – Thickness
You will find that pool table felt is available in a range of different thicknesses, which is especially relevant for tables made from certain materials. The thickness of the felt can help with cushioning and will help the balls to run across the surface more smoothly.
A thicker felt will also be more hardy and will be able to stand up to repeated use, without suffering wrinkles or snags. The manner in which the felt is manufactured will be one of the main processes to consider as a close weave is necessary.
2 – Color
The color of the pool table felt can do much to change the look of the table, even making it appear larger or smaller than it actually is. This should be taken into account when choosing the color, as will the longevity of any unusual colors.
If you are considering felt of an unusual color, think about whether this will clash with anything else in the room or if it will become dated. The décor of the room where the pool table is situated must be considered if a cohesive look is desired, as well as the table itself.
3 – Installation
If you are completing the work of fitting the pool table felt yourself, you will need to consider the method of installation and how easy this will be to achieve. On large pool tables, you will often find it necessary to undertake some disassembly in order to secure it properly. Alternatively, you will need to consider the labor cost of having it installed by a professional.
4 – Accessories
When fitting pool table felt, you will require a number of accessories and tools. You will need to take into account the accessories that you will be required for the project. In the event that the felt doesn’t comprise a suitable backing, you will also need to obtain a lining that can be laid beneath the felt.
If the felt will be fixed in place with staples, remember that you will need the tool to enable you to insert the staples. It is important to keep the felt flat when fitting it, which may require the use of a flat edge to smooth it down as you fit it.
5 – Warranty
Consider whether the manufacturer of the felt offers any guarantee in respect of how long the felt will last with normal use. This will give you an idea of what period you can expect to pass before the felt wears down and when it needs to be replaced.
