Login Error
Close
5 Tips for Applying for No Doc Home Loans
by DoItYourself Staff
You can apply for no doc home loans, however, it may be difficult to find lenders or financial companies that will allow a home loan without certain documents. No doc home loans are home loans that do not require job verification, proof of income and sometimes even credit checks, to get a loan. Knowing what to do and what you will need for a no doc home loan is essential. Below are some tips you can follow.
1. Be Honest
The best advice that you can get when applying for no doc home loans, or any other loan for that matter, is to be honest with the lender or financial institution. Being honest allows the lenders to check all information you give, and at the same time provide an accurate estimate on the terms of the loan. Also, being honest helps you get away from any fraudulent cases that the lender may file against you. It is important to remember that putting information in your application to make it more appealing to the lender, is not a good idea if it isn't truthful. Lenders will find out the correct information.
2. Make a Larger Down Payment
In most cases, lenders do not check the credit ratings or standings of applicants of no doc home loans. However, this is the same reason why it is important that you prepare to pay a larger down payment, compared to if you were applying for a regular home loan. It is best to pay at least a 25 percent down. Generally, the lender or financial institution will give you an exact amount, as to how much the down payment should be, to qualify for a no doc home loan.
3. Check Your Credit Rating
Although most lenders may not check your current rating or standing, it is still best to check where you stand. A higher credit rating will make it easier for you to get a no doc home loan. However, if you do not have a near perfect credit rating, it is advisable to pay-off a few of your installment loans, to keep your credit rating up.
4. Do a Self-certification
To obtain a no doc home loan, it is best to do a self-certification process. This involves you providing all the necessary documents, to convince the lender that you have the ability to pay the loan.
5. Choose the Right Kind of No Doc Home Loans
There are several types of no doc home loans. It is important that you research each of these loans, to help you better understand which one fits your situation best. A No Ratio Loan is suitable for those who may have a hard time getting documentation of their income. The debt to income ratio is not considered in this type of loan. NINA or no income-no asset, is to guard a person’s privacy. However, this may require a look at your credit rating. Lastly, Stated-Income Loans are no doc home loans for those who rely mostly on fluctuation incomes, like bonuses or commissions.
 forum activity
