Login Error
Close
5 Tips for Choosing a Natural Gas Garage Heater
by DoItYourself Staff
It is important for you to install a natural gas garage heater in the garage of your home to protect your equipment, yourself, and your loved ones from the cold during chilly months. There is a wide variety of natural gas garage heaters available at your local home improvement or hardware stores. Make sure you familiarize yourself with the needs of your home and your garage so that you can choose the garage heater with the best features to suit your needs.
1. Choosing a Convection Heater
The first basic type of natural gas garage heater is known as the convection heater. This garage heater circulates the air around heating tools in the heater unit and emits this heated air out into the room or garage where you installed it. Make sure that your garage or room has an electrical outlet or electricity source available so that you can plug this heater unit. Also, it is highly suggested that your garage or room has a source of ventilation so that the warm air can circulate and not pose as a health threat to you or your family members.
2. Choosing an Infrared Heater
An infrared garage heater makes use of natural gas. This gas source is safe for the environment. This heater, however, does not need an electricity source since it makes use of electromagnetic radiation to produce the heated air needed to warm you garage. The heater has enough power to warm or heat up the areas around or near the garage heater.
3. Features that a Garage Heater should have
Most, if not all heaters come with certain features. Depending on the size of the garage heater that you purchases, a natural gas garage heater may have the capacity to heat up a garage that stores up to 2 or 3 cars. Natural gas garage heaters are equipped with a thermostat control that you can use to adjust the temperature or heat level to the amount of heat you want. They also come with mounting brackets and other safety features to keep you and your loved ones safe when it is installed in your garage.
4. Advantages of Natural Gas Garage Heater
An advantage to installing a natural gas garage heater is that it has the power to provide self-contained heat. There are a number of types of heaters out there that do not require the use of electricity in order to function. These can therefore provide heat to your garage even during black outs. Natural gas garage heaters are simple and easy to use, and they function well. These units are also safe for the environment because they only use up natural gas.
5. Disadvantages of Natural Gas Garage Heater
One thing to keep in mind is that once you install a natural gas garage heater, it is permanently installed I that area. If you wish to remove it, you may need to contact professional technicians to assist with this process. You will need to provide a source of ventilation to prevent the harmful effects of gases such as carbon monoxide.
 forum activity
