Login Error
Close
5 Tips for Connecting a USB Ethernet Adapter to Your Video Game Console
by DoItYourself Staff
If you've recently purchased a USB ethernet adapter for your home gaming console, you're probably wondering how to go about setting the device up. While this may seem like a complex task for the technologically impaired, it can actually be completed in a simple and stress-free fashion.
Confirm that You Own the Right Type of Console
Only newer video game consoles are able to support such an attachment, so before committing to buy, confirm that your console of choice possesses a port for USB devices. These ports can generally be found on the back ends of video game consoles, but just to play it safe, you may want to consult your console's owner's manual or the manufacturer's website in order to confirm the port's location. Also, make sure that you own a Sony PlayStation 3, a Nintendo Wii or a Microsoft Xbox 360. Previous generations of gaming consoles are not equipped to handle USB ethernet adapters, as they were manufactured before such attachments were commonplace.
Purchase the Right Type of USB Ethernet Adapter
When it comes to video game consoles, not just any USB ethernet adapter will do. Make sure that you purchase an adapter that is specifically designed to work in conjunction with gaming consoles. Traditional adapters require you to install a number of device drivers that video game consoles are not equipped to handle, so make sure to select the right one. Fortunately, Sony, Nintendo and Microsoft all produce first party USB ethernet adapters for their respective video game consoles, thus narrowing your options. These adapters can be purchased at virtually any electronics shop or video game specialty store, as well as various online retailers.
Make Sure Your Console is Turned off
Although this step may seem like a no-brainer, make sure your video game console is turned off before attempting to connect your adapter. Connecting or disconnecting things from your console while it is running is liable to cause lasting damage to the device and can even result in electrocution. If you want to be extra-cautious, feel free to turn off the television to which the console is connected, too.
Locate Your Video Game Console's USB Port
Now that you've selected a suitable ethernet adapter, you'll need to locate your gaming console's USB port. This port can usually be found on the console's back end, but you may want to consult your owner's manual to be sure. Next, connect the USB extension of the adapter to your console's USB port. If your ethernet adapter is wireless, this is the only physical connection you will be required to make. If not, connect the adapter's line extension into one of your router's unoccupied line ports.
Connect Your Gaming Console to Your Home Network
Having connected your USB ethernet adapter to your router, you'll now want to turn on your console and access its network settings screen. If you're unclear on how to access this screen, consult the console's owner's manual. Next, make sure your console's network name is the same as your router's. If your router has a particularly potent signal strength, the name of its network may already be pre-selected. Lastly, select "Infrastructure" as your console's network mode. Save your settings and you're all finished.
 forum activity
