5 Tips for Decorating Your Fireplace Hearth
Your fireplace is often used as a focal point of any room because of its grandiose structure, which is why you should be very meticulous with decorating your fireplace hearth. Although it’s usually the mantel that is given close attention to, the hearth also deserves to receive the same kind of pampering like the other parts of the fireplace. Not only is the hearth often the center of attention when the fire is burning but it is often dirtied after the flames have died down. This is why it’s very important for you to keep the fireplace hearth looking presentable all the time, whether you actually use your fireplace or not.
1. Painting the Hearth
Often when you use wood for your fireplace, the interiors are damaged easily especially when the paint is concerned. This is why if you want to keep your hearth looking neat all year round without having repaint everything every now and then, you should invest in a few coats of polyurethane paint. This paint actually produces a clear matte finish that protects the existing color of your fireplace hearth.
2. Using Tiles
Another great way to highlight your fireplace hearth is to install tiles. You can choose from so many types of tiles out on the market right now. There are ceramic, glass, terra cotta and porcelain. Choose the kind of tile that will help tie your fireplace with the rest of your room. If you’re looking for that more natural and rugged look, you can opt to install terra cotta tiles. If you are going for a more modern approach, glass usually works well to achieve that look.
3. Rugs
Rugs are great because they lend that warm quality that is usually lacking in a bare room. Other than the aesthetic value, rugs actually protect your floor from the embers that jump out from your fireplace. This allows you to simply remove the rug whenever you need to clean up. Invest in a rug that has the color that you desire but made of durable and synthetic material. Stay clear of the valuable Persian rugs or antique rugs that cost a fortune if you don’t want to see them damaged by the embers.
4. Wrought Iron Candle Holder
If you aren’t using your fireplace anymore, that does not mean that you should stay clear from any kind of light coming from that area. You can always substitute the flames of a fireplace with candles in your hearth. You can place a wrought iron candle holder on your hearth to create that same feeling of a lit fireplace.
5. Tools
Placing ornamental tools on your fireplace hearth is a convenient way to spruce up your fireplace. Especially if your fireplace is rarely used, you can always fake usage by placing ornamental tools on your hearth in an attempt to fool your visitors into thinking that you have the tools because you do use the hearth. Real tools won’t hurt too.
