5 Tips for Installing Fiber Optic Cables Yourself
Undertaking fiber optic cable installation is an ideal way to ensure that you get the best from your electronic equipment. Being aware of a few tips will help you to fit the cables yourself without encountering any problems.
Type
Effective fiber optic cable installation will make it necessary for you to obtain the correct cable for your purposes. The type of cable you use must be relevant to the equipment it is to be used with to ensure that you get the best result. In addition, different cables use a different number of fibers which are variously known as single-mode or multi-mode. When they are necessary, further fibers can be added to the existing cable.
Fitting
Ensure that the cable you buy is long enough for the use you intend to put it to so that it does not become stretched to reach from one appliance to another. This can cause damage to the components of the cable and affect the validity of fiber optic cable installation. Besides this, you should also avoid twisting or bending the cable excessively as this can result in permanent damage which will require it to be replaced. Some cables will contain a rod that limits it ability to be bent, but you should still avoid bending it where the rod is not present. Avoid moving equipment without removing the cables first as this can result in kinks in the cable which will damage the fibers.
Ensure that the cables you use have effective cable grips to enable you to install and remove the cables when necessary to prevent the need to pull at the jacket of the cable which can cause damage.
Compliance
Make sure that any cable that you purchase complies with all the relevant regulations necessary. This will ensure that is has gone through the correct manufacturing process and that it has passed inspections to prove that it is safe to use. The packaging for the cable should confirm what regulations it complies with and that it is safe to use as part of your fiber optic cable installation and the cable itself should also show the relevant markings.
Connectors
The fiber optic cable installation should be as simple as possible and you will be able to ensure this is the case by choosing an option with spring-loaded connectors that are easy to use. Additionally, the connectors are one of the main components that dictate the performance of the cable so it is important that they are highly conductive. Connectors made of gold will help in this regard.
Size
Besides being aware of the length of cable that you require, you should also take the thickness of the cable into account. Thicker cables will often have the most number of fibers and will enclose a rod within the plastic coating which will prevent the cable from being bent or twisted. There are also thin and lightweight varieties that will have more flexibility which will be useful if your equipment are arranged in an unusual manner.
