Login Error
Close
5 Tips for Mounting Wall Speakers in Your TV Room
by DoItYourself Staff
Television rooms equipped with wall speakers provide an elegant and sense-surround feel, as if you are inside a cinema. Wall mount speakers include the benefit of not taking the actual space inside the TV room. When you are installing or arranging a home theater in your entertainment area, these wall speakers can produce that fascinating theater surround sound. You can also camouflage or design your speakers to conceal them inside the room.
Since you have to drill holes within the walls to attach these speakers, installing these wall speakers is actually not an effortless task. You have to ensure that the wall is empty, and that there is nothing within the wall like the support beams. You also need to figure out the process of installing the wires for the wall speaker, particularly if the audio source is coming from another room.
Prepare the Tools and Materials Needed
Before mounting or installing any of the speakers on the wall, you have to prepare the materials and tools first so that you aren't interrupted while you are doing the mounting process. Set the power drill, key saw, bits, measuring and marking tools, as well as the wall speakers and wires, in a close and convenient location.
Searching for the Right Location
Select the right location for the speakers within the wall.  You need to observe the location of wall hoops, which support the boards inside the wall that are placed, by tapping along the walls and then listening for a monotonous reverberation sound.
Drilling and Making Holes
Drill a hole inside the wall, in which you know that there is no stud, and then insert a wire inside the hole to sense around the locations of the studs.
Next, cut a hole inside the wall, which is a precise size for the wall speaker. Sketch the outline of the speaker on the wall using a visible marker, chalk, or pencil making use of the speaker ends as a guide. Make a half-inch hole for every corner of the outline-made and then cut out the sketch using a key saw.
Mounting the Speakers
You need to determine how you are going to attach the speaker wires throughout the wall. Once the audio source or amplifier is in the same room as the theater, you can simply drill a hole next to the floor and pass the wire down the floor’s edge and up throughout the wall. When the source is coming from another room, you need to snake in the wire from the other area.
Make a hole inside the wall next to the floor within the other part of the room. If you prefer to run the wire throughout the basement, drill the hole inside the floorboard of the wall, insert the drill downwards through the speaker hole that you cut. Pass the wire throughout the hole coming from the other area through pulling it coming from the speaker's room.
Finishing Touches
Attach the wires with the speaker and then mount the speaker to its hole. Oftentimes, the wires are screwed in place along the terminals at the back of the speaker then the speaker should be screwed or bolted into the wall. Make sure that the speakers are working before cleaning up.
 forum activity
