Login Error
Close
5 Tips for Painting a Baby Crib
by DoItYourself Staff
An attractively well-painted baby crib tends to be the centerpiece in a baby’s room. Many a times, old cribs need to be repainted while some need to be repainted to change the color to accommodate a new baby of a different sex. The article discusses some tips that can help you when you paint your new-born's crib.
Getting the Crib Ready to be Painted
If the crib has never been painted, sand the wood using sandpaper and clean it with a cloth. Use a primer to seal the wood. Just in case, the crib has been painted before, strip the paint off and then sand the wood before applying the primer.
Choosing the Right Color and Brush
Select the colors that need to be used. It is best to use neutral colors like white, yellow, etc. if you do not know the sex of the baby. Otherwise, use pastel colors and complementary colors if you plan to use more than one color. Using spray paints is not advisable, as it can easily reach the inside of the slats. Ensure the paint box says ‘lead free’. Milk paint is environmentally safe and safe for the delicate baby. This is available at most DIY and home improvement stores. A roller is much better than a paintbrush as it gives a smooth and professional look.
Post-Painting Tips
The paint must be given enough time to dry before it is repainted. Allow the paint to air dry, before applying the next coat. Allow at least two days for the crib to completely dry and disperse the fumes. Use a cloth or newspaper to protect the floor from paint spills and drips. Lastly, when completed, keep a few bowls of white vinegar around the room for 4-5 days. This will help absorb all paint fumes and make it safe for the baby.
 forum activity
