Login Error
Close
5 Tips for Sizing Your Heating Ducts
by DoItYourself Staff
Heating ducts provide heated air inside a home. When installing a heating duct, it should be properly sized in order to provide the home with the proper heating requirements. When installing heating ducts that are too small, then the air volume needed for the heating task will decrease. Making the ducts too large will make energy cost a lot more expensive. To make the duct work effective, the heating duct size should be calculated correctly. Read on for more information.
Tip No 1 – Ensure Correct Ducting Size
Make sure to calculate the ducting size correctly to avoid spending too much on energy costs. Know how much air is needed in a specific area in order to calculate the ducting size. The standard sizing is at 0.1 inches per 100 feet of duct. Remember that making the duct size too large will make the energy cost rise.
Tip No 2 – Know the Required CFM
The recommended sizing is at 1 cubic feet per minute (CFM) per one square foot of space. If a specific room measures ten square feet, it means that the required CFM would be 10-square feet of CFM. The CFM calculations will affect the entire sizing of the heating ducts.
Tip No 3 – Use a Duct Calculator
An easy way to measure the required ducting size for a room is to use a duct calculator. The duct calculator can be downloaded online. The software does not need to be purchased since some websites provide it for free online. Usually, the calculator will calculate a 100 CFM to need 6-inch diameter duct work. Take note that the diameter of the heating duct will depend on the area to be heated.
Tip No 4 – Combine Heating Requirements of Separate Rooms Altogether
If another room needs heating, then simply add the area of the room to the calculation. Since each room will depend on the needed CFM calculated, make sure to measure the entire area of the room to be heated accurately. Therefore, if one room needs 100 CFM and another needs 200 CFM, then the heating duct requires a higher duct work area. To make the calculation a lot easier, make use of the calculator.
Tip No 5 – Install the Appropriate Duct Size Connections
Once all the rooms are considered for duct size considerations, increase the duct size accordingly. Run the correct duct size on the furnace and install the ducts correctly. Installing the duct incorrectly will affect the heating capacity of the heating system. Therefore, if there are air leaks in the duct system, then the heating system will also be affected.
In order to avoid the heating system losing its efficiency, it is best to install the heating duct correctly by fitting all joints securely. Another thing to consider is to insulate the heating system. The size of the heating duct is useless if the heating system is not insulated properly.
 forum activity
