Login Error
Close
5 Tips for Smoothing Silicone Caulk
by DoItYourself Staff
Silicone caulk is very useful for sealing bathtubs and other fixtures. It can help stop water and moisture from seeping into joints. However, it can be challenging to apply smoothly and achieve a good, even finish. There are a number of ways to ensure your silicone caulk looks perfect when you apply it. They’re all simple methods and you’ll quickly be able to have your silicone caulk work looking perfect in no time.
Masking Tape
The best way to achieve an even bead of silicone caulk is by using masking tape. The tape will keep the caulk from smearing. It will also give you a straight line and will help the caulk to be applied smoothly.
To do this, apply masking tape to the wall above the bathtub and another line of tape to the tub itself. You should allow just enough space for a bead of silicone caulk. The tape needs to be straight. When you remove it after smoothing the caulk, you’ll be left with sharp, straight lines of silicone caulk.
Finger
You can smooth the caulk down easily with your finger, running it in a long line along the bead of caulk. This can take some practice since you have to keep an even pressure and try to run along the entire length without stopping, if possible. It can take two or three tries to achieve real smoothness.
There is a trick to it. Before you begin, wet both your finger and a rag with alcohol. The alcohol is both a cutting agent and a lubricant which means your finger will move easily over the caulk. The silicone caulk will need to be cleaned off your finger periodically.
Speed
It’s important to start smoothing the bead of silicone caulk before it begins to dry. Once the drying begins, it can be almost impossible to achieve a properly smooth bead. You need to approach the caulking confidently and not worry if the bead from the tube is even; when you smooth it out, your fingers will fill in the small gaps with caulk.
Damp Rag
You might well find some small ridges left after you’ve run your finger down the silicone caulk. To remove these, use a damp linen rag and run it lightly along the bead. This will create a very even, professional finish to the caulk.
Work In Sections
Don’t try and smooth the caulk around a whole tub at once. You’ll achieve much better results if you work in sections. This way. you can proceed quickly and smooth the silicone caulk before it starts to dry and develop a skin.
Allow the caulk in one section to dry before you move on to the next section. This means taking more time but the results with your silicone caulk will be much better. Finally, pull off the masking tape working away from the caulk.
 forum activity
