Login Error
Close
5 Types of Solar Panel Kits Explained
by DoItYourself Staff
Instead of paying a company to install Solar Panels, many homeowners are choosing to buy their own Solar Panel Kits. Solar power is created when the sun’s energy is absorbed through solar cells and then converted into regular direct current electricity. Solar energy saves a lot of money on household bills and there are many measures that can be taken to ensure good savings and a solid solar installation.
Solid fuel prices are on the increase and currently run in the region of 20 cents per kWh (kilowatt per hour). However, the average cost of solar electricity is currently as little as 10 cents per kWh (kilowatt-hour). That is a saving of 50% against ‘on-grid’ electricity. Another upside of producing your own power is that on occasions when you produce more electricity than you need you can sell it to your local utility company for a fee. So, not only do your fuel bills reduce, but if you make more than you need, you could end up actually getting free fuel.
Normally a solar panel kit will include everything you need in order to install it safely in your home. Solar-powered systems work on a modular basis, in which they allow the freedom to create the exact setup that you need. You can dictate your own level of voltage and current to suit your household needs.
Starter Kits
Installing a starter kit in your home will guarantee that in the event of a grid power cut you will have some form of electricity available in your home to ride the storm. These kits are usually one or two panels which you can wire to a battery in order to store the energy up during daylight hours. It will offer you and alternative in the event that you home power is interrupted. Although, the wattage you will get from a starter kit is lower than if you buy a larger kit.
Solar Lighting Kits
These kits are specifically geared toward just your lights. They will not be wired to any other part of your home and will only power the lights in your house. They come in various wattage rates and you should buy the correct wattage for your desired output.
Solar Heating Kits
These will wire directly into your home heating system and offer a high rate of fuel efficiency as well as low or zero household heating bills. Wattages differ from kit to kit, so do some research on the amount you will need to run your home to maximum efficiency.
Solar Fridge and Freezer Kits
These will switch the power you use to run your fridges and freezers to solar power. The main advantage of these kits is that in the event of a power failure or blackout your frozen and chilled foods will not get wasted. The solar powered fridges and freezers will maintain the correct level of power supplied to them in order to keep them running until the mains can be reconnected or reinitialized.
RV Solar Panel Kits
Running your RV could not be more simple if you install a solar panel kit. They will run off a 12 volt battery. Depending on how often you use your RV you can choose between a 20 watt and a 40 watt system. The 40 watt system is for higher usage, so if you travel in your RV frequently then 40 watts is more suitable.
 forum activity
