5 Vinyl Siding Parts and How to Keep Them Clean
There are several different vinyl siding parts that are needed for a correct installation. Many people do not realize that there are several extras that need to be purchased in order to make the vinyl siding look right when the project is completed. Vinyl siding is very popular among homeowners today because of the very low maintenance. The siding does not have to be painted, and it can be cleaned very easily. If you are not familiar with vinyl siding parts or want to know how to clean them, here is a short guide for you.
Vinyl Siding Panels
The actual vinyl siding is the most visible part. These are lengths of PVC that are formed to look like wood siding. They are generally four inches wide and up to 12 feet long. Installing this vinyl siding is very easy when you have the right tools on hand. Basically, you need a chop saw, a hammer, and some galvanized nails. They interlock together for a weathertight seal.
Vinyl Siding Starter Strip
This part is a very thin piece that is used to start your first course of vinyl siding panels. There is a small lip on the bottom that hangs over the bottom as a drip edge. This is to keep water from flowing back under the bottom row of vinyl siding.
Utility Trim
Once you get up to the top of the house, you will need to install a utility trim. This goes just under the eave in order to attach the last row of siding. Again, this helps to create a weatherproof seal between the eaves and the wall.
F-Channel Trim Pieces
The F Channel vinyl siding part is used for holding the pieces on the soffit in place. It gives the overall eaves and ceiling a more finished and professional look.
J-Channel Trim Pieces
These small pieces are installed around any windows, doors, or other obstructions like power meter, electrical boxes, and the like. When you get to the edge of a window, the end of the vinyl siding will go into the J channel in order to keep any water from getting into the seam.
Cleaning Vinyl Siding Parts
There are plenty of different products that people can use to clean their vinyl siding parts. However, if you use a pressure washer a few times a year on the vinyl siding, it can remain quite clean. For stains, bird droppings, or tough grime, a good homemade cleaning solution is very effective.
Homemade Cleaning Solutions
There are two great cleaning solutions that you can use in order to clean the vinyl siding parts. The first is for mild cleaning and is made up of one part of dish detergent and 5 parts of water. For heavier cleaning, you will need to use one part of bleach with 3 parts of water. This will get rid of any mold buildup or caked on dirt.
How To Clean Vinyl Siding Parts
Once you have hosed down the siding with a pressure washer, you simply wash the siding with a brush, or a sponge soaked in the cleaning solution, then rinse it all off with the washer.
