6 Advantages Of Basement Wall Insulation
Basement wall insulation can help you conserve energy, save money and increase your living comfort indoors. You can have your basement walls insulated from the exterior or the interior. Both methods have their advantages and disadvantages.
Reduces Energy Consumption
Insulating your basement walls provides a protective cover that shields your home from temperature fluctuations in extreme climates. Basement wall insulation helps in temperature regulation, keeping your home warmer in the winter and cooler in the summer. You can reduce the energy you consume by operating the heater or air conditioner at lower intensities.
Lowers Moisture Content
Inadequate insulation in the basement leads to moisture accumulation, condensation and a phenomenon known as ‘weeping walls.’ These problems over time lead to the growth of mold, mildew and fungi in the basement. The structure of your home can get badly degraded and become unstable over time. Mold and mildew also cause serious health problems in the inhabitants of a household. By insulating your basement walls, you can significantly lower your risks of encountering these issues.
Increases Indoor Comfort
By insulating your basement walls, you can greatly increase your comfort level indoors. The insulation is highly effecting in preventing heat loss during the winter. It also works well to retain cool air during the summer months. You can prevent the temperature inconsistencies that are common in homes with poor insulation. With basement wall insulation, indoor temperatures tend to be consistent through the home.
Protects Water Pipes from Freezing
In colder climates, water pipes in the basement are prone to freezing. This can cause damage to the pipes and necessitate costly repairs. Basements that are well insulated do not have this problem.
Protects Foundation from Water Accumulation
Basement wall insulation that is applied on the exterior of the building is effective in protecting the structure from water on the outside. Freeze and thaw cycles in colder climates can have damaging effects on the foundation as well. By acting as a buffer against the structure and the surrounding soil, external basement wall insulation effectively protects the structure from moisture problems.
Available in Many Varieties
There are several types of basement wall insulation available, ranging from concrete and foam board to blanket insulation for unfinished basements. Finished basements can use foam spray insulation, which is easier to use on existing structures.
The main drawback of basement wall insulation is that it is a costly process for existing buildings. You have the choice of insulating your basement from the exterior or interior. Exterior wall insulation requires extensive work on the outside and also alteration of the surrounding foundation and soil. It is costlier than interior insulation, but provides better protection. It prevents moisture absorption on the outside and prevents condensation and moisture problems. Interior basement wall insulation is cheaper and requires less work, but it does not protect the exterior of the building from moisture. It also results in a reduction in the living space in the basement, because the insulation takes up space indoors on the walls.
