6 Advantages of Installing a Pullout Kitchen Sink Faucet
A pullout kitchen sink faucet is considered a necessity in many households. It makes completing chores in the kitchen easier because of the many benefits it offers. If you don't already have one, consider these advantages for installing a pullout kitchen sink faucet:
Advantage 1 - Control Water with One Hand
Washing dishes or cleaning the sink area involves a lot of multi-tasking, and your hands are often full. The advantage of a having a pullout kitchen sink faucet is that you can control water with just one hand. It's convenient to use because you can still do something else simultaneously with your other hand. For example, you can spray water into a dirty sink with one hand, and scrub with the other.
Advantage 2 -Hose Down Vegetables
These are excellent when you want to spray and wash your vegetables. When you hold your vegetables under a typical faucet, you have to roll them around with your hands in order to loosen any dirt or other contaminants. The sprayer works like a mini hose and can do that work for you.
Advantage 3 - Can Install on Many Sinks
You can install a pullout kitchen sink faucet on a wide variety of sinks. There are many options, but the same is not true for the other type of faucet sprayer: A spout sprayer. Let's say you have a old sink to work with. You're probably going to be able to install a pullout sprayer with little problems. You probably won't be able to do the same with a faucet sprayer built in to the spout on an older sink though.
Advantage 4 - Reaches Beyond the Sink
It's possible to extend a pullout kitchen sink faucet to at least four inches to reach areas near the kitchen sink. You'll need this capability to complete some of your kitchen chores. For example, filling up a mop bucket using a regular kitchen faucet can be hard to do. If you have a large bucket, you won't be able to fill it up and lifting it can strain your back. With a faucet sprayer, you can fill up the bucket with ease, by directing the flow of water into the bucket.
Advantage 5 - Makes Washing Simple
There often isn't much room in the sink to wash larger pots and pans. For example, washing a roasting pan under a regular kitchen faucet can be a hassle. You eliminate those headaches associated with trying to cram large pans under the sink to wash them with a pullout kitchen sink faucet. Simply spray water into the pan to wash and rinse right on the counter or in a kitchen sink.
Advantage # 6 - Water Indoor Plants
If you grow plants and flowers indoors, then you'll enjoy the benefits of a pullout sprayer. Find the one with the longest reach possible, and you may not have to use a watering can again. You can also control the rate of water flow, which is ideal when you're watering your plants.
If any of these advantages appeal to you, then consider buying a pullout kitchen sink faucet for your sink. You'll expand your capabilities in the kitchen and simplify many of your kitchen tasks.
