Login Error
Close
6 Advantages of Installing Corrugate Fiberglass Roofing
by DoItYourself Staff
Corrugated fiberglass roofing is one of the more recent entrants in the roofing sector. It is a synthetic roofing material made from extremely fine glass fibers. These fibers are embedded in an organic resin to create a translucent laminate. Corrugated fiberglass is designed in a wavy pattern of ridges and grooves that alternate. Should you choose to install this material on your roof, you can count on several advantages.
1.   Versatile
Corrugated fiberglass is available in various grades and colors. Some designs even allow light to filter through easily. However, the roofing is designed in such a way that it keeps out direct sunlight and excessive heat. Filters in the roofing block the harmful UV rays. Fiberglass roofing blends well with various structures. It can be used with excellent results as roofing for your house, garage, patio, carport or greenhouse. You can also install fiberglass roofing over an existing roof. This saves you time and money.
2.   Affordable
Corrugated fiberglass is one of the cheaper options for roofing materials. Yet it performs well as a roof and keeps your home well protected. It makes a good choice if you’re on a tight budget yet desire quality and durable roofing material. The cheaper price allows you to complete your construction projects faster without being constrained by cash.
3.   Ease of Installation
Fiberglass roofing is one of the easiest roofing materials to work with. You can easily cut or saw through it. When you need to drill or nail through the material, this can be accomplished without damage to the fiberglass. It is one of the lightest roofing materials. This reduces the demand for labor to carry the fiberglass sheets. It helps to keep your installation costs down. The material is also flexible and bends easily to fit in the roofing frames. The ease of installation contributes towards a faster turnaround.
4.   Excellent Drainage
Corrugated fiberglass roof panels funnel rainwater and snow from the roof with high efficiency. This eliminates accumulation of water on your roof. You’re unlikely to have problems with leakage if you install a corrugated fiberglass roof. This helps to protect your property and keeps you safe.
5.   Durable
In spite of its fair price, fiberglass is one of the most durable roofing materials on the market. It is resistant to rot and insect damage. Fiberglass holds up well to the elements. Prolonged exposure to the sun doesn’t affect the color. It also bears contact with moisture very well. This makes it ideal in various climatic zones. Fiberglass has a higher resistance to fire than wood and vinyl. It also has high tensile strength which contributes towards a strong roof. The corrugated pattern further adds to the resilience of the roofing. This makes it one of the most durable roofing materials available. Some manufacturers even offer a lifetime guarantee.
6.   Low Maintenance
Fiberglass isn’t attacked by rust or corrosion, which reduces the maintenance work required. You need not worry about periodic application of coats of paint or other treatments. Various varieties incorporate anti-algae properties, which cuts down on the work required to keep your roof in good condition. Besides, you don’t require special products to clean your fiberglass roof. A mild detergent, water and a scrub brush are enough to get the job done effectively.
 forum activity
