Login Error
Close
6 Advantages of Owning a Refrigerant Leak Detector
by DoItYourself Staff
If you’re looking for ways to ensure your fridge doesn’t leak uncontrollably, a refrigerant leak detector offers one solution. This handy device will help you identify the leaks in your refrigeration system easily and accurately. It can detect the presence of leaks as well as trace the source. This enables you to take remedial action. The detector is a useful diagnostic tool if you hope to maintain an efficient fridge. Although you can locate leaks the old fashioned way, a leak detector does a much better job. Below are 6 advantages of owning one.
1. Increased Operating Efficiency
Leaks in the refrigeration system are a major cause of fridge inefficiency. Leaks can be difficult to detect manually due to the time and effort involved. Manual methods also don’t give you as much accuracy in pinpointing leaks. When leaking is unchecked, the refrigeration system suffers pressure losses. This hinders the refrigerator from operating at its best. More energy must also be utilized in operating the fridge.
2. Better Quality of Food
When a fridge leaks, besides affecting fridge efficiency, it also impacts negatively on food quality. Undesirable emissions from refrigerant can infiltrate food items stored in the fridge. A leaking fridge may do you more harm than good. Dairy products and other fresh produce are especially at risk. These are very sensitive to the storage environment. If conditions are not properly controlled, the foodstuffs can easily spoil or get contaminated. This compromises the health of household members.
3. Minimizes Repair Costs
Undetected leaks can result in increased financial problems for you. If not detected early they can cause malfunctioning of the fridge. This may necessitate costly repairs. Replacement of parts may also become necessary. With a fridge detector you’ll be able to diagnose the fridge whenever desirable. You need not call in a technician to do the job. It helps avert high maintenance costs.
4. Improved Energy Efficiency
Leaking fridges use more electricity to function. This ultimately creates higher power bills for you. With a leak detector, you can help check leaks on a regular basis. This helps to improve on energy efficiency of the refrigeration system. With increased energy efficiency, you can look forward to reduced power bills.
5. Minimizes Health Risks
Refrigerants can have deadly effects on health. When inhaled or ingested, proper functioning of the body is disrupted. This compromises the health and well being of household members as well as pets. Leak detectors are very sensitive and can accurately pinpoint the leaking areas in the fridge. With such a device you’ll be better able to reduce the health hazards associated with refrigerant in the household.
6. Environmental Safety
Some refrigerants deplete the ozone layer. This exposes us to increased ultra violate rays. Refrigerants may also act as greenhouse gases which contribute towards global warming. Ultimately, the risk of developing certain diseases such as skin cancer increases. A leak detector helps you control these dangerous emissions into the environment.
 forum activity
