Login Error
Close
6 Advantages of Using a Digital Clamp Meter
by DoItYourself Staff
You’ll find a digital clamp meter a useful device for various electrical works. It often becomes necessary to ascertain electric current readings of domestic appliances. This enables a more thorough diagnosis of a particular problem. It also allows efficient repairs to be undertaken where possible. The digital version clamp meter gives accurate measurements of the electrical current available in wires. It is an efficient way of testing loads in a circuit without having to break the circuit. If you’re looking for a safe and efficient way to go about your electrical work, this device is a must-have. Outlined below are 6 advantages of the clamp meter.
1. Convenience
The digital type clamp meter is a small convenient size. It is lightweight and easily held in the hand. Many clamp meters require you to cut through wires when measuring the electrical current. The digital version spares you from this cumbersome routine. It is easy to use the various functions. You get your readings faster and with far less effort. You don’t require electricity to use the clamp meter. The device utilizes batteries to take readings. This makes it more reliable due to the constant power source. When batteries run low you can simply recharge or replace.
2. Efficient
The digital clamp meter gives you live electrical readings with high accuracy. It doesn’t disrupt the operations of the appliance being tested. You need not lose time by having to turn off an appliance. It is a more efficient way of accessing current readings.
3. Liquid Crystal Display (LCD)
The clamp meter utilizes a digital display system unlike analog types. This gives precise readings in figures. It is a quicker and more efficient way of getting information on electrical current. The LCD also spares you from having to strain when taking readings. The display may also carry other vital information. This alerts you of what needs to be attended to.
4. Multi-Purpose
Due to its various enhanced features, you’re able to use the clamp meter for several tasks. The clamp meter has a dial which is useful in selecting whatever aspect you wish to measure. You can test current, frequency, continuity, capacitance, resistance and voltage. The multi-purpose aspect adds to the efficiency of the clamp meter.
5. Higher Safety
Reading current without having to cut through wires is a much safer way of taking readings. Devices that require you to break the circuit in order to read the current flow subject you to increased danger. Should something go amiss, you may suffer electrocution.
6. Low Maintenance
The digital type clamp meter is a light device with few moving parts. The device doesn’t run on a motor. Gadgets that use motors are more subject to frequent breakdowns. The clamp meter is battery operated which provides more stability. The low maintenance requirements add to its durability. Many of the digital clamp meters on the market come with a warranty of as many as 5 years.
 forum activity
