Login Error
Close
6 Advantages of Using LED Porch Lights
by DoItYourself Staff
The use of porch lights is an added security for home or building owners because they illuminate the doorway or entrance to our properties. Since the lighting fixtures may be left on overnight every night, choosing the right kind of porch lights is important. Thus, the use of LED, or light-emitting diode, light sources is strongly suggested. This kind of light uses a semiconductor technology first used as indicator lights only for certain appliances. Now, with their intense lights, several LEDs may be combined in a fixture to create a lamp. In these lights, electrons release energy in the form of photons, and the color depends on the energy emitted.
To better explain why you should use LED porch lights, here are some advantages of using them over the incandescent and fluorescent lights.
Energy-saving
LED porch lights are more cost-effective than the other types available in the market, such as incandescent and fluorescent lights.
Incandescent lights, which are composed of a glass-covered tungsten wire through which electricity passes, are light yellowish and cannot brighten up any area that efficiently. The main reason for this is that almost 90 percent of the electricity they use is transformed into heat, not light.
Fluorescent lamps light up when mercury or gas vapor electrons inside the glass are excited by the passing of electricity. They produce white light and are better at illuminating porches than incandescent lamps. However, part of their electrical energy is also converted to heat energy.
Low-Maintenance
Aside from being cost-effective, LED lights can prove to be easier to maintain. As they have a longer lifespan, replacements of your porch lights will not be that frequent. Incandescent lamps often get busted and must be replaced very often. Fluorescent lamps, meanwhile, may operate between 1,200 to 20,000 hours, but their brightness dwindles over a certain period of time.
LED lights use less energy and produce less heat. The lifespan of an LED light can range from 25,000 to 100,000 hours, making it very convenient to use and maintain.
Durable
LED lights can be arranged in a compact fixture without compromise to their durability. Unlike incandescent lights and fluorescent lights, which are enclosed in glass, LED lights are not susceptible to breakage because they have no glass components. They are more resistant to vibration or outdoor impacts compared with the other lamps.
Better Sense of Security
Homeowners may have a better sense of security, as they may not need to replace their lights over and over again. There is also a smaller chance of their lights' getting busted in the middle of the night or at dawn.
Safety
LEDs do not contain mercury, which is present inside fluorescent lamps. Exposure to mercury is deemed detrimental to a person's health, as it can cause respiratory, visual and behavioral problems and even death.
Decorative
Aside from their practical advantages, LED lights offer an aesthetic advantage since they are actually composed of tiny individual lights. They can enhance the beauty of a porch, depending on how they are arranged.
 forum activity
