6 Advantages of Using LED Rope Lighting
Lots of homeowners and others are using LED rope lighting for interior or exterior spaces. LED or light emitting diode lighting is a new innovation in home or commercial lighting design that replaces traditional halogen lighting. When these lights are strung into a plastic housing in a linear design, they are called LED rope lights. Here are some of the main benefits of using LED rope lighting anywhere on a property.
Lower Energy Use
Because LED lights rely on a less energy intensive model than the traditional incandescent lights where a filament lights a bulb, those who opt for LED rope lights can save a lot of energy and a lot of money over time. Some experts estimate that LED lights use about one sixth of the energy that a halogen bulb would. This makes LED lights a good choice for thrifty property owners who want to conserve energy, especially where areas will be continually lit.
Longevity
LED bulbs also last a lot longer than traditional incandescent bulbs. Where a halogen bulb would burn out in something like 1500 hours, LED bulbs can last literally dozens of times longer, for up to 50,000 hours of light according to manufacturers. This leads to less maintenance and more savings.
Durability
LED lights are able to be placed inside durable containers, and include less fragile parts than traditional bulbs. That makes it easy to install LED lighting in areas that experience a lot of traffic, or exterior areas where there may be some periodic turbulence.
Less Fire Risk
The innovative technology in LED rope lights leads to more fire safety in homes and commercial spaces. Part of the reason that LED lights don’t use as much energy as traditional incandescent is because they throw out less energy in the form of heat. Traditional lights can get extremely hot; LED lights, by contrast, do not experience the same elevated heat levels. This makes them less of a fire risk and lowers the risks of burns when human skin comes in contact with the light source. In LED rope lights, the light source is effectively shielded by thick plastic.
Series Circuit Capacity
Older types of traditional rope lighting tended to have problems if they were based on a series circuit. When one bulb would burn out, the subsequent bulbs would also fail to be lit. LED rope lighting eliminates these kinds of issues.
Color and Style Options
LED rope lights are available in many different color combinations and handy styles for outfitting exterior areas, like patios, or interior hallways, bar areas or home or commercial installations.
These are just some of the main advantages of using LED rope lighting for various areas of a property. These attractive lighting options can be extremely easy to install, and may save property owners a lot of money. Next time you’re in the market for additional light sources, think about using LED rope lights and how these choices can improve an interior or exterior space.
