Login Error
Close
6 Benefits of Copper Wiring
by DoItYourself Staff
Copper wiring has been around for many years and is still commonly used today. With copper wiring, you are presented with a number of different benefits. If you plan on doing any wiring in the near future, copper wire should most likely be in your plans. Here are a few of the many benefits that you can get by using copper wiring in your wiring project.
1. Best Conductor
Out of all of the different metals and wire out there, copper is the best conductor out of all of them. You can get more power in a piece of copper than with any other option you have. This makes it efficient and helps you get the job done better than you could otherwise.
2. Flexibility
When you are using an electrical wire, there is a good chance that you will need it to be flexible. When you wire something in a house, you will most likely have to bend the wire around several different things. You might have to go into a very precarious angle to get the job done. This makes copper wire very desirable as it is very flexible. Even though it has some flexibility, you are not going to lose any toughness, either. It is not brittle when you bend it, so it will not crack or break.
3. High Melting Point
It really takes a lot to melt a copper wire. Therefore, if you are worried about safety, copper wire is going to be one of your best options. If an overload or surge comes through the wire, it is not likely to melt or burn. This means that your odds of a fire starting as a result of a power problem are going to be greatly decreased.
4. Does Not Loosen
When you use copper wiring in a home, you are less likely to have to go back and fix it in the future. When materials other than copper are used to wire things, they can sometimes loosen where they are connected and come unattached. This can lead to some seriously dangerous conditions and waste a lot of time fixing everything.
5. Avoid Incompatibility Problems
Most appliance and electrical equipment manufacturers specify that copper wire is in all of their products. When you do not have copper wiring in the walls of your home, this can cause an incompatibility problem in the future. If you try and run a non-copper wire up to a copper wire, it could cause a galvanic action and start some serious problems. This could effectively destroy the copper wire that it is attached to. This could cause you some serious work in repairing the entire system. Getting copper from the beginning will make everything a lot easier in the long run.
6. Easy to Work With
Most electricians prefer to work with copper wiring because it is very easy to work with. You can strip it easily, pull it through tight spots, and not have to worry about surface oxides forming on it. It truly is the best choice for wiring a building.
 forum activity
