6 Best Spots to Mount a Home Alarm System Dial Pad
A home alarm system provides effective protection against burglaries and break-ins. Statistics show that a reliable alarm system can almost eliminate chances of a burglary. The dial pad is the central part of your home alarm system, and it is the interface that you will use daily to enter your security codes. You may have multiple alarm system dial pads if you have a larger home. It is important to place the dial pads strategically so that you can access them in minimal time when needed. Some of the best spots to mount a home alarm system dial pad are enlisted below.
1 – Near the Main Door
This is the most frequently used entry and exit point in most homes. It is imperative to install a dial pad for the home alarm system near this door. As soon as you get back home, you can reset the alarm before it goes off. Placing the dial pad as close to the door as possible makes this job easy and convenient.
2 – Inside the Garage
The garage is also a key spot where you can install the dial pad. It is used daily as the exit point and is also the most convenient spot in which to use the dial pad when you drive in after work and enter your house.
3 – Near Side Door
Most homes have a side door that acts as the secondary point of entry to the house. It may also be used as the entry to the backyard. As such, it is also a vulnerable point in your home, and installing the dial pad close to this area can serve as a good reminder to activate or disarm the alarm system, as required.
4 – Near Patio
The patio or back door in most homes is widely used, especially in the summer. The alarm system dial pad can be used every time someone enters or exits through this way. If it is not installed and the dial pad is at the front door, some lag time must be taken into consideration so that the alarm is not triggered.
5 – Near Entrance from Garage
In addition to being the input point for the security key, the alarm system dial pad is also often the interface you use for communicating with the alarm security company. Installing the dial pad near the entry point from the garage is a good idea, because this door is often used the most, especially in cold weather.
6 – In Master Bedroom
In situations of emergency, you will need the dial pad for the alarm system close to you. Installing the dial pad in the master bedroom will prove to b a boon in the unfortunate circumstances of a break-in in the middle of the night. You can even use the “distress mode” if it is available on your system. In this mode, the alarm system acts like it is normal, even while it is sending a message to the security company that there is a critical situation in your home.
