6 Best Uses for a Reciprocating Saw
A reciprocating saw, also known as the Sawzall or a Sabre saw, is basically an electric saw that is used for cutting wood, metals and piping. There are various jobs that require different tools, but a reciprocating is an all in one tool that can take the place of several others. The saw uses a pull and push motion of the blade to cut. It is widely used for vertical or obscured places that no other types of saw can work with. You can cut through difficult areas like the corners and floors without a fuss. This is one of the best tools invented to make life easier to deal with. In this article we will show you the best uses for a reciprocating saw.
1. Make an Indentation on the Walls
This is for when you are remodeling a unit and need to place wiring on the walls. A reciprocating saw is highly recommended when trying to make an indention on the walls where you will be running a wire, especially in odd places. t.
2. Changing PVC Piping
A PCV pipe is normally located in obscured places. Often, there is nothing more effective than a reciprocating saw. You can cut through the pipe even if you are in a very awkward position.
3. Cut through Difficult Nails or Pins
Take advantage of the reciprocating saw when cutting through nails or pins that are difficult to remove. If you are working on a project where there is no other way to pull out a nail because of its tough hold, you can use a reciprocating saw to cut the head of the nail and not bother pulling it up. You can also use this with pins in the same way.
4. Cut Tree Branches
If you need to take down branches in your yard, this is the perfect tool for the job because of its toughness and cutting power. Why bother chopping it down with an axe when you have a fully equipped cutter that does not need man power.
5. Fitting a Window
The reciprocating saw is what professionals use to cut down or fit a window since it can work in obscure and uncomfortable places, where a normal saw cannot function.
6. Cut through Different Materials
When cutting with a reciprocating saw, anything goes. You can use it for cutting any material, whether for wood or metals. You can use it in odd places on most any type of object.
