6 Best Uses for Acrylic Latex Paint
Some of the problems that occur in the aftermath of using acrylic latex paint will make it an inappropriate option for a number of household tasks. However, understanding what this paint can be used for around the home will help in this regard and ensure that your acrylic latex paint retains it's integrity
Wood
Using acrylic latex paint on wood surfaces can be beneficial whether it is inside or outside. This is due to the fact that it is flexible and can handle any movements that occur, especially when it comes to extremes of temperature. For interior locations, such as wood trim, it is beneficial because it is durable and easy to clean. It is ideal for use in rooms such as the bathroom and kitchen where temperatures can quickly change and cause the wood to expand and contract.
Crafts
Acrylic latex paint is ideal for use in relation to a number of arts and crafts because it is available in a great number of colors and dries quickly. Whether you are painting a canvas, a toy model or an item of furniture, you will find that latex paint is the ideal choice. For larger artistic pursuits, such as murals, the paint can also be useful as it can be applied using an airbrushing method as well as a brush or roller. The process of creating designs on decorative items such as toy boxes and vases can be completed with the help of acrylic paints.
Masonry
External wall surfaces including concrete, stucco and bricks can be painted with acrylic latex paint. It is resistant to peeling, cracking and flaking due to its flexible nature, which helps to keep external surfaces looking good for a long period of time despite being exposed to the elements. The color with these paints are also long-lasting so do not quickly fade. The paint will take better of you initially clean the surface thoroughly.
Furniture
The range of materials that various items of furniture can be made from means that acrylic latex paint is an ideal choice for a number of different pieces. Whether the furniture is made from wrought iron or plastic and is used indoors or outdoors, using acrylic paint is the perfect way to change the color and protect the surface. This will enable you to wipe the surfaces when it is necessary to clean them.
Walls
The paint is available in a range of different finishes which means that it can be one of the options that you choose from when considering what to use to paint internal walls. In addition to it being able to be used for the entire surface of the walls, it can also be used to add painted designs on top of existing paintwork or wallpaper.
Doors
Although the paint is not suitable for items that are to be completely immersed in water, it is capable of withstanding small amounts of water. This makes it a good option for the external surface of front doors and patio doors. The changes is temperature will not affect the paint and will stop water from affecting the wood.
