6 Decorating Tips For Your Mobile Home
A mobile home is an affordable alternative to a traditional home. Whether you opt to position your mobile home in the woods or in a semi-permanent park, you must decorate your home with style. Although the rooms are small, you can decorate each according to your tastes to create a cost-effective but homely environment that works for you.
Tip 1: Painting
Most older mobile homes come with paneled interior walls that are somewhat dark. Paint the strips of molding in between each panel of wallboard. White works well in most homes, giving a crisp, spacious appearance. Use warm reds or greens in the living room, or simply apply a coat of primer and some semi-gloss finish to the panel to give it a rich look. You can always remove the paneling, but this is time-consuming and might ruin the walls.
Remember to paint the ceiling as well, which may have become dingy or water-stained. Simple white paint will brighten the appearance of the room and make it look fresh and clean.
Tip 2: Floor Treatment
Remove the dull brown carpeting that came with your mobile home and opt for tile or wood tile instead. Use rugs to create a cozy setting. You can highlight your stove area with a neutral rug. Throw rugs enhance the appeal of tiny spaces so keep a few around, but take care not to create clutter.
Tip 3: Furnishing and Upholstery
Do not clutter your rooms; one large piece of furniture is better than a few pieces placed in a room. When picking upholstery, choose plain colors over prints to make the area look spacious. Do not use drapes or heavy curtains on your windows but opt for lighter material instead. You can get blinds to match the color theme, or tint your windows to prevent excess light from coming in.
Tip 4: Cabinets
Changing your cabinets will give your mobile home a new look. Shop for cabinet that are lightweight and suit your theme, selecting honey-colored or light oak. But if you want to do with your current cabinets, apply a coat or 2 of simple white paint to give them a fresh look.
Remove your cabinet doors and replace with frosted or plain glass for a stylish look. De-clutter your kitchen by removing excess cabinets.
Tip 5: Bathroom
Paint your bathroom a bright color to make it look bigger, and paint any cabinets white. You can even use faux marble contact paper to give it a stylish look. Invest in towels in deep colors and throw in a small rug.
Tip 6: Indoor Appearance
Mount a mirror horizontally on any unoccupied wall to create the illusion of a bigger room.
Decorate walls with old pictures or mounted prints to give a warm, inviting look. Add plants, either on the floor or hanging, to add some color and life to your small space.
