6 Different Types of Projector Screens Explained
There are many different types of projector screens available on the market, and the choice can be quite confusing to a prospective purchaser. Depending on your needs and available space, you must carefully select the right type of projector and projector screen.
1 - Permanent Projector Screens
These are one of the pricier options available. You can install a permanent projector screen if you have the required space reserved for an entertainment area. Permanent projector screens are useful in different environments such as conference rooms in offices and also at home, where they are used in the same location.
2 - Portable Projector Screens
Portable projector screens are a less expensive option, and offer great flexibility. You can take the projector screen when you travel. You can also move it to different rooms in your home, if you do not have area set aside for a home theater. Portable projector screens can be easily set up and dismantled, but it is cumbersome to repeat the entire process if you change locations often.
3 - Retractable Screens
Retractable screens offer you the flexibility of rolling up the screen when it is not needed. Retractable screens are available in manual and electric models. The manual screens are more economical and easier to install. You can manually roll up the screen into a protective casing when you do not require it open. Electric retractable screens offer automatic roll back when you press the appropriate button. These screens are more complicated in installation and also cost more. Retractable screens offer the added benefit of keeping the wall free to hang decorations when the screen is not in use.
4 - Front Projector Screens
If you have a projector that projects images from the front of the screen, then you need a front projector screen that is compatible with it. The projector is located behind the audience and the images it projects on to the screen bounce back from the surface of the screen, making it appear to the viewer. Front projector screens are easy to install and use. They are best for use in surroundings with minimal light.
5 - Rear Projector Screens
Rear projector screens are designed for use with a projector that projects images from the rear of the screen. The projector projects images through the screen to the viewer. This is called rear projection, and it requires some extra space set aside for the gap between the screen and the projector. Rear projector screens typically offer better viewing results as compared to front projector screens. However, a minor disadvantage is that a bright spot may sometimes be seen in the center of the screen, because the projector is right behind.
6 - Curved Projector Screens
Curved screens offer a very bright output, because the light is directed at the viewer. The amount of light that bounces off the screen is minimized because of the curvature, making the picture more legible and bright.
