6 Features to Consider in a Combination Washer-Dryer
When purchasing a combination washer dryer, there are several things that you should consider. Consider the features below before purchasing a combination washer dryer.
1. Moisture Sensor
One of the most attractive features that you should look for is a moisture sensor. This will allow the machine to detect when all of the moisture is gone from the clothing. With this feature, you will not have to leave the dryer on for a certain amount of time regardless of how wet the clothing is. Instead, the moisture sensor will turn off the dryer when all of the moisture is gone. This will help you save energy and it will also make your clothing last longer.
2. Electronic Controls
Another feature that you will find in many modern washer dryer combinations is electronic controls. Electronic controls are a lot easier to work with and allow you to do a number of different things. Instead of having to turn a knob, you can simply push a few buttons to begin the process. Many of these allow you to set a specific time for your wash or dry cycle to begin if you do not want to do it right away.
3. Sanitizing Cycle
On some of the newer models, you will also be able to find a sanitizing cycle. This feature heats up your clothes to a very high temperature and helps sanitize them. If you are worried about germs or bacteria or if you have children in your home, this can be a priceless feature.
4. Anti Vibration System
Some of the nicer models on the market have an anti-vibration system that keeps the dryer from shaking when it is running. One of the biggest complaints that many people have about traditional dryers is that they vibrate while they are in operation. This can be loud and distracting, and it can even damage the floor or waste water by causing unbalanced loads. With the anti-vibration feature, you can eliminate this problem.
5. Quiet Operation
Some washer-dryer models also have a quiet operation feature. This makes the entire process of washing and drying your clothes much quieter than what you might be used to with a washer and dryer. If you have a small house, it can be nice not to have to listen to the cleaning process.
6. Efficiency
You may also want to find a washer dryer combination that is considered to be efficient. You can find models that use a very small amount of water and electricity, and many of these units will feature an Energy Star rating. This means that it meets the government standards of energy efficiency and it is one of the better models on the market for conserving energy.
