cancel
Job type :
Zip Code :
community forums
comments
6 Features to Have on a New Deadbolt Lock
Several features of your new door deadbolt lock can enhance your safety and peace of mind. These include electronic keypads, automatic door locks, remote door lock access, keyless door handles, biometric deadbolt locks and alarms to alert you to problems. Continue reading to learn more about these features.
Electronic Keypad Deadbolt Locks
These eliminate the need to carry keys and replace lost ones. You can program these locks with any of 10,000 different combinations, using 2 to 8 digits. Change the combination as often as you like, and be sure to select a passcode identification not connected to your personal information. Avoid using a birthday, address or telephone number. Electronic deadbolt locks can be installed on more than one door of the house. Change the door handle to a contemporary lever style, or keep a more traditional round door knob. Battery life for these locks runs up to 2 years, and you can purchase the batteries anywhere you buy locks.
Automatic Door Lock after Opening
Many electronic keyless deadbolt locks have an optional feature that automatically locks the door after it has been open for 10 seconds. This is a great option if you are shepherding small children into the house or frequently bring in heavy loads of groceries.
Remote Door Lock Access
A small remote control, like that for your car, can release your door latches from as far away as the driveway. This is helpful for people using mobility assist devices to ensure the door is open and ready to swing out of the way when they reach the entry. The remote batteries last for 1 to 2 years.
Keyless Door Handles
An electronic locking system can still be thwarted if the door handle has a key lock. Remove this means of access by purchasing a new keyless door handle with your electronic keypad locking system. Since the majority are battery-operated, you will still be able to get into your home in the event of a power outage.
Biometric Scanner Deadbolt Locks
Choose the latest in security features for your new deadbolt lock by purchasing a biometric scanner deadbolt lock. This can be programmed to read just your fingerprint and one or two others of your family. No longer do you need to remember passwords or worry about keying them in before the alarm activates. These run on long-life independent battery systems that last from 2 to 5 years.
Alarms on Your Electronic Deadbolt Lock
Most electronic deadbolt locks come equipped with a set of audible alarms that will tip you off to the door being locked, unlocked, a low power reading for batteries, and a jammed lock. You can hear these distinct signals for only a short distance, usually within 4 feet of the door.
When you choose a new deadbolt lock that has even a few of these features, the payoff in greater security for your family and possessions will be priceless. Many are easy to install yourself, but to assure effective lock operation, contact a qualified locksmith to install the lock for you and show you how to use it efficiently.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
Painting Stylish Wall Borders
sponsored articles of the day
