Login Error
Close
6 In-Ground Pool Safety Tips
by DoItYourself Staff
There are several inground pool safety procedures you must follow to maintain a certain level of safety while using your pool. Below are some helpful in-ground pool safety tips that you can follow.
1. Using Pool Covers
Since in-ground pools are far easier to get to than an above-ground pool, it is important that you provide precautions to limit the access of the swimming pool particularly among children. Using pool covers is a great way to limit access to an in-ground swimming pool. Aside from protecting the pool water, a cover can prevent the use of the pool by children without the supervision of adults. It can also keep animals and pets from diving into the pool. If you live in area where wild animals can get access to your swimming pool, a pool cover can provide great protection for your pool.
2. Pool Signs
An obvious way to keep your in-ground pool safe from all its users is to put up signs all over the pool where every one can see them. If you have additional features in the pool that may cause harm, it is advisable that you put signs detailing the entire do’s and don’ts in using the pool. If you have a rock formation in your pool, you may put a sign saying it is slippery when wet and to avoid using the rocks as a diving board if you do not want to.
3. Depth Markers
Although you may find markers or signs of how deep the pool is in public pools, it is also a good idea to incorporate this safety practice in your private swimming pool. This way, swimmers can tell which portion of the in-ground swimming pool is deeper. This is a great way for different level of swimmers to know which side of the pool they should and should not swim.
4. Usage of Pool Chemicals
Since the use of pool chemicals cannot be avoided it is important that you use the correct mixtures and levels of chemicals in your pool. Otherwise, it can cause different health risks to the users. Too much pool chemical solutions can cause skin irritation or even allergic reaction. On the other hand, if you put in below the required amount your pool may be inhibited by bacteria and other pathogens that have harmful effects to your health.
5. Pool Lighting
Whether you have an in-ground or above-ground swimming pool, it is important that you have a well-lighted one. Do not just be satisfied with outdoor lights that are coming from your home. Make sure that you install lights right by the pool area. It is also a great idea to put in pool lights or underwater lights. Aside from providing additional design and mood to your pool, it can also provide great lighting for your pool.
6. Maintenance of Pool Drains, Vents and Filters
Another important safety tip for your in-ground swimming pool is to keep your pool drains, vents or filters free from cracks or holes. This is to prevent clothes from accidentally getting hooked on to these. A well-maintained filtration and drainage system can also prevent the formation of bacteria and germs from getting in your pool.
 forum activity
