6 Reasons to Install a Kitchen Pegboard
A kitchen pegboard is a board that has several holes at a fixed distance from each other. These holes can accommodate hooks, where you can hang utensils and other kitchen commodities. A pegboard is usually made of wood or metal. Wood is considered more appealing to the eye, but is not as durable and sturdy as metal, which can take heavier loads. Listed below are some of the reasons to install a kitchen pegboard in your home.
1 – Minimizes Clutter
Most of us keep kitchen cookware and utensils in storage cabinets and drawers. Sometimes it can be frustrating to look for something and having to spend time searching for it. Most kitchens also have limited space in the cabinets and drawers. As a result, many of the items end up outside on the counter, giving the kitchen a messy, cluttered look. A pegboard has many hooks where you can hang your pots and pans, strainers and containers. You can free up space in the drawer and organize your kitchen in an attractive way.
2 – Makes Items Easy to Access
It is much easier to locate something on an open pegboard than to rummage through a kitchen drawer or look through floor-level storage cabinets. You can have everything you need available close by, wherever you install the kitchen pegboard. You can also accommodate special shelves on your kitchen pegboard if they are compatible. On these shelves you can keep containers of spices, which makes them easy to find during cooking. You can attach storage bins to accommodate smaller items as well. You could even attach small appliances to the pegboard and save more space.
3 – Easy to Install
All you have to do to install a pegboard is to find an appropriate spot and attach it there with screws. Larger pegboards can get very heavy as you hang items on them. It is therefore advisable to install anchors to avoid damage to the wall.
4 – Can be Customized According to Need
Pegboards are very adjustable, and can be customized to every need. You can cut them in different shapes and sizes according to the space available in their intended location. You can also match your kitchen pegboard with the existing décor by painting over it or applying matching wallpaper on it.
5 – Available in Many Varieties and Shapes
Pegboards are available in wood, hardboard and metal. Wood can crack or show deformation under heavy loads. Metal is more resilient and longer lasting. It is also impervious to the heat and moisture that is usually prevalent in most kitchens. Pegboards are available in many different varieties and colors. You can also make modifications as per your individual needs and requirements.
6 – Can be Installed in Different Locations
A kitchen pegboard can be installed on the wall, behind the door, on the ceiling and even inside cabinet doors. This way you can maximize the use of space and keep things in order. Kitchen pegboards are ideal for use in smaller kitchens where storage space is often minimal.
