Login Error
Close
6 Reasons to Install Bifold Shower Doors
by DoItYourself Staff
Bifold shower doors add a sleek and modern aspect to the shower enclosure. The doors consist of shaped folding sections. These are set on some rollers contained on a set of tracks that allow them to slide when opened. Bifold doors open inwards into the shower like an accordion. However, they do not take up much space when opened. Bifold doors are a practical solution for efficient space utilization in the bathroom. Consider the advantages of bifold shower doors listed below.
1. Space Saving
Space is often limited in the bathroom. This creates a cramped bathroom where relaxation as you shower is hampered. Fortunately, you can improve on some of the inadequacies in your bathroom. Opt for design ideas that make maximum utilization of space. The bifold design is ideal for small bathrooms. The doors blend well with the restricted space. They do not encroach much into the shower enclosure. This enables you to shower in a much more relaxed way. You need not be restricted by shower doors which can be an obstruction to movement in and out of the shower enclosure.
2. Better Shower Access
Since the doors take up little of your shower space, it allows greater shower access. This improves the functionality of your shower. You can shower in a more comfortable environment. This is both relaxing and therapeutic. It also makes it a lot easier for the elderly or disabled to use the shower, without much discomfort due to space restrictions.
3. Ideal for Corner Bathrooms
Corner bathrooms require specific design aspects to make them more comfortable. Space is often a limitation in the corner bathroom. Bifold doors blend well with the design features of a corner bathroom. They allow efficient utilization of space while promoting the functionality of the shower.
4. Versatile
A wide range of bifold doors are available on the market. The doors come in different materials, styles and colors. Some of the colors you'll find include white, transparent, silver and chrome. These blend well with most bathroom decors. If interested in glass doors, you can select from transparent, tinted or frosted. Glass is a trendy choice. It gives a sleek look to the bathroom. The doors can be made to fit whatever size you require. This makes it easy for you to find what suits your needs.
5. Less Water Drips outside
Bifold doors open inwards into the shower. This prevents much water from dripping onto the bathroom floor. You will have less work cleaning up a wet floor after shower usage with bifold doors. This will save you time, which boosts your time efficiency.
6. Inexpensive
Not only is the bifold door design practical for shower enclosures, it is also affordable. The doors are available in a wide range. The flexible range makes it easy to find something that fits your budget and suits your bathroom needs.
 forum activity
