6 Reasons to Keep a Roll of Duct Tape Around
Duct tape is a very popular item that can be used in a number of different applications. With its versatility, it is always a good idea to have a roll of duct tape around the house. Here are a few reasons that you might want to consider keeping a roll of duct tape around.
1. Fix Ducts
As the name implies, you can use this type of tape to seal up ducts. If you have a duct come apart, you can use duct tape to seal up the joint between the two pieces of duct. This will keep the air in the duct and will hold it together tightly.
2. Fix Leak
Duct tape can also be used to fix leaks. This works especially well whenever you have a water hose that gets a hole in it. To quickly repair the hose, you can simply wrap the area with a little bit of duct tape. It should stay on the hose well and it will not allow water to spray out through the hole. If you need a temporary solution with water pipes, you can also use duct tape. Wrap the duct tape around the pipe thoroughly and this will buy you some time until you can replace the pipe.
3. Bandage
Although it might not be the ideal solution, duct tape can also be used as a bandage. For example, let's say that you are out in the wilderness and you get a severe cut on your leg. If you happen to have a roll of duct tape in your backpack, you can wrap your leg up with it. It will seal up the wound and prevent too much blood from escaping. It will also help keep it clean so that bacteria cannot get into the wound.
4. Weatherstripping
You can also use duct tape as weatherstripping around doors and windows. By applying a few layers of duct tape, you will be able to properly seal up your door or window. This will prevent air from getting in and out around the door. This can help you significantly lower heating and cooling costs over the course of the year.
5. Vacuum Repair
If you get a hole in a vacuum cleaner hose or a bag, you can use duct tape to repair it. Simply wrap the hose with duct tape around the damaged area and this will allow the air to flow through the hose again. You can also catch up a hole in the vacuum bag with a piece of duct tape if you need to.
6. Remove Lint
If you do not have a lint roller handy, you can also use duct tape to remove lint from your clothing. Simply take a clean piece of duct tape and press it against your clothing. When you pull the duct tape off, all of the lint will come off with it. You can then discard the duct tape with the lint attached.
