Login Error
Close
6 Reasons to Use Mirror Brackets
by DoItYourself Staff
Mirror brackets are used everywhere: homes, offices, shops, cars and trucks. Depending on their use, mirror brackets come in different shapes, sizes, colors and materials. Sometimes, using mirror brackets may be a matter of choice but more often, it is a necessity. Let us look at different reasons to use mirror brackets.
Reason 1 - Easy to Install
Mirror brackets are easier to install than the alternative method of adhesion, which is sometimes used. Using adhesive can be messy and requires more care while handling. You have to be very careful not to get adhesive on your hands and fingers. In addition, any adhesive carelessly visible on the sides of your mirror can ruin the look and make it look sloppy and untidy.
Reason 2 - Visually Appealing
While adhesion works best in small corners and serves to hide or embellish them, mirror brackets can add to the kind of look you are trying to create in your home or personal office. A large mirror placed on a wall in a prominent place will enhance the harmony of the décor if you use mirror brackets of a complementary color and material. If you are planning to give your waiting room or guest room the antique look, rusted or rust colored mirror brackets will be the perfect choice. Add an old antique mirror frame and your look is complete.
Reason 3 - Strong Support
If the mirror you want to install is large and heavy, you should use mirror brackets because they will provide the strongest and most secure support. No alternative will provide the same kind of security. Therefore, if you want to avoid having your beautiful, expensive, antique mirror in pieces all over your dining room floor, you should invest in mirror brackets.
Reason 4 - Secure
No matter how strong adhesive is, it is bound to become weak after a few years. There have been several cases where bathroom mirrors, that were installed when the house was built, came off without warning and crashed on the person toweling himself dry in front of it. Steam and warmth in a bathroom cause the adhesion to melt and thus loosen the hold on the mirror. It is a much securer option to use mirror brackets to avoid having a mirror fall on and injure your children.
Reason 5 - Easy to Maintain
It is much easier to clean a mirror that is held on brackets because you have space to move all around your mirror. Additionally, if at sometime in the future you decide to change the placement of the mirror, it is much easier to remove the mirror brackets than it would be to remove adhesion. Removing adhesion will definitely ruin your wall and most probably cause damage to the mirror as well.
Reason 6 - Perfect for Vehicles
On a car or truck, brackets help to keep the mirror close to the body. Otherwise the mirrors will shake and vibrate when the vehicle moves. Rear view mirrors and tow mirrors need to be adjusted often, and mirror brackets provide the freedom to twist and turn the mirror in a convenient direction for best visibility.
 forum activity
