Login Error
Close
6 Safety Tips for Using Drain Cleaner
by DoItYourself Staff
When dealing with chemicals such as drain cleaner, it is wise to do so in a safe manner. Toxic substances should always be handled with care and under adult supervision. If you have a lot of children in your home, your safest option is using drain cleaners that are chemical-free.
Tip 1 - Avoid Harmful Cleaners
When choosing a drain cleaner, avoid cleaners that contain lye or acid. These chemicals can harm your health, waste water or PVC pipes. If these cleaners are your only option, wear gloves and a mask when dealing with them. Make sure you securely lock them away when finished or place the cleaners on a high shelf to keep away from children. Opt to choose cleaners that come with a safety cap built in if you have children.
Tip 2 - Use A Sewer Jetter
A sewer jetter can completely eliminate a blocked drain. The advantage of a sewer jetter is that you can alter the speed of the spray pattern. The deeper the clog, the more force you can use when using the sewer jetter. To remove heavier clogs, you can use a flushing action. This can be done with a laser nozzle. Always set your spray pattern to 90 degrees. The advantage of a laser nozzle is that you can alter the pressure of the water coming out of the hose. Since this tip only involves water, it is safe for the pipes and no chemicals will enter your air flow.
Tip 3 - Prevent the Buildup of Grease
To prevent the buildup of grease down the drain use a salt water solution. By pouring this mixture down the sink, odors will vanish and grease will not build up. Since this is a safe mixture, it can be used frequently to keep clogs from occurring. The best way to fix a clog is to prevent one. By preventing one, you can avoid using chemical drain cleaners altogether.
Tip 4 - Always Read the Labels on Drain Cleaners
Some drain cleaners can destroy plastic drain pipes so read the ingredient labels with caution. You don't want to create another problem for yourself. Always make sure that the drain cleaner you are using is safe for garbage disposals and plastic pipes. Avoid cleaners that burn your hands and sting the nostrils. Usually these chemical cleaners are more harmful than helpful. Some drain cleaners can also harm metal pipes, so please read carefully.
Tip 5 - Use a Natural Drain Cleaner
For clogs you can use baking soda followed by colorless vinegar. Remove any standing water in the drain. Pour 1/2 cup of baking soda into the drain with the clog, then pour 1/2 vinegar into the drain. The reaction that will take place between these two substances will clear up the clog. The plus side is that your will refrain from using any chemicals. If the clog still doesn't go down or if the clog goes down slowly, you can repeat the procedure. Unlike Draino, vinegar and baking soda will not damage your pipes, so frequent use is safe.
 forum activity
