Login Error
Close
6 Soffit Lighting Design Tips
by DoItYourself Staff
Soffit lighting is an excellent means of producing an ambient glow or mood. Soffit fixtures light the area underneath a structure. This can include: dropped ceilings, the area between the ceiling and the tops of cabinetry. Sofitt home lighting fixtures can provide both functional light and mood light by placing fixtures in well placed spots in a room. If your home doesn't have soffits, you can have them added through dropped or inverted tray ceiling installations. Soffit lighting is an excellent means of producing an ambient glow or mood. Consider the following design tips as you plan your soffit lighting.
1 - Direct and Indirect Soffit Lighting
Soffit lighting fixtures can provide both direct and indirect light effects. Light fixtures focused on a specific area, such as track lighting, is a form of direct lighting. Light fixtures that illuminate larger areas, such as recessed lighting, is a form of indirect lighting.
2 - Track Soffit Lighting
Traffic soffit fixtures are a popular lighting option because it can be made to easily changed to meet the design and decorating needs of the homeowner. These lights can be turned full circle and they can also be moved up and down the track to different positions. Track soffit fixtures provide an endless lighting possibilities.
3 - Recessed Soffit Lighting
If you are attempting to create a mood with lighting but have no soffits, false ones can be built. This type of soffit is the best for recessed lighting because it does not contain any pipes like most true soffits do. Recessed soffit lighting fixtures can be connected to a dimmer to allow the homeowner to change the amount of light produced. It provides much more control over the atmosphere in a room.
4 - Kitchen Soffit Lighting
Lighting is an essential element in kitchen design. Overhead lighting fixtures can cast shadows in areas where we actually require more light. This problem can be easily solved by installing direct soffit lighting fixtures over kitchen cabinetry, These lights usually hold small round fixtures with movable bulbs. The bulbs can be positioned into any direction necessary. This feature in kitchen soffit lighting can create a soft glow or provide a direct source of light to work space. The fixture can be installed in a box between the ceiling and the cabinetry.
5 - Living Room and Den Soffit Lighting
Lighting fixtures are a vital tool in creating room ambience or drama. Soffit lighting near the ceiling can add a beautiful, soft glow. Wall art displays can also be accentuated with well positioned fixtures. Soffit fixtures provide additional lighting and removes the need for adding more lamps to a room.
6 - Exterior Sofftit Lighting Fixtures
Exterior soffit lighting can provide homeowners with a sense of security and ambience. These lights can be used to light up the landscape and prevent burglars from entering the area. They can also make a walkway safe when arriving home after dark. Exterior soffit fixtures can be installed across the entire front of the house in place of dated house lighting. These fixtures are positioned in areas that are more difficult to reach preventing them from becoming damaged or removed. Soffit lighting can also be used to highlight particular landscaping displays you may have in your yard.
 forum activity
