6 Symptoms of Low Clutch Fluid
Clutch fluid is one of the vital fluids required for a vehicle engine to function. It is also commonly referred to as transmission oil or break fluid. The fluid reduces with time during vehicle usage. It becomes necessary to top up fluid in the clutch reservoir as need arises. A leak in the clutch reservoir will also result in declining levels of the fluid. Leaks are more likely to occur at either the slave cylinder or master cylinder. If left unattended, low fluid levels can cause serious damage to your vehicle. You can ascertain the level of the fluid by inserting a dipstick in the reservoir. However, certain signs during driving are a likely indication of insufficient fluid. Below are 6 signs of low transmission fluid.
Vibrations when Shifting Gears
When all is well with your car’s engine, shifting gears should be a relatively smooth process. Stuttering or other resistance during gear change is most likely a sign of declining transmission fluid levels. Inadequate fluid oil makes it difficult to undertake gear shifts efficiently. It is best to top up the fluid level whenever due. Otherwise the pressure on the mechanical parts to execute certain functions is greater. This leads to increased vehicle wear and tear.
Gear Slippage
Transmission fluid enables proper transmission of force during all gear selections. When the fluid is low, the hydraulic power required for smooth gear shifting is absent. This results in frequent gear slippages. You’re likely to experience a slip in the clutch pedal’s point of engagement. No matter what gear is selected, transmissions fail to engage. This leaves the car seemingly stuck in neutral position.
Sluggish Gear Shifts
Adequate clutch fluid enables quick and accurate gear shifts. When transmission fluid is low, slow or sluggish gear shifts are the norm. More effort is required to do gear shifts. This can make driving a laborious experience.
Vehicle Lurching
Low fluid levels may cause the vehicle to lurch forward and backwards when driven. Insufficient fluid causes erratic transmission movements during vehicle operation. It becomes impossible to achieve a smooth and easy vehicular motion. Lurching can easily be eliminated by ensuring transmission fluid is at proper levels.
Loss of Springing Action in Clutch Pedal
Adequate clutch fluid allows you to operate the clutch pedal efficiently and accurately. The pedal ought to spring back into position swiftly when released. However, insufficient transmission fluid prevents the smooth movement of the clutch pedal. Sometimes the pedal fails to reach to the end point. It may get stuck before it reaches the furthest end.
Grinding Noise
Insufficient transmission fluid may result in a grinding noise when the clutch pedal is operated. Inadequate lubrication causes the clutch mechanism to strain as it functions. Sometimes unusual noises simply indicate the need to top up engine fluids. It is best to check your fluid level immediately you take note of any abnormal noises. If left unchecked, it could easily lead to serious damage and more costly repairs for you.
