6 Tips for Installing Wood Window Trim
If you have decided to install wood window trim to the windows around your home, there are a few tips that you should keep in mind. Installation can be complicated if you do not have the right knowledge or tools, but a few simple steps can make the process much simpler and more efficient.
Tip 1 - Selecting a Wood Trim that You will Enjoy
It is important that you select a trim that will go well with the rest of your apartment, as well as one that will last a long time. Make sure you look at different styles and shades before selecting your trim as the wood will be a part of your home. Though you can stain or paint the wood later, the color may not seem as natural.
You will also need to discuss with your dealer the style of the corners of your trim. Most dealers will cut the trim for you and will help you go over which corner style will be easiest for you to install for your specific size of window. Choosing these things carefully at the beginning can save you work later on.
Tip 2 - Get Exact Measurements by Marking the Wood
Though your dealer may have cut the wood to the approximate size of your window, there will usually be a little more cutting for you to do at home as the measurements are usually not exact. If you do need to cut your wood a little more, hold it up to the window frame and mark the exact length you will need to cut it. This will make sure that you have the exact length and width you need.
Tip 3 - Pre-Drill Nail Holes
When attaching the trim to your window casing, it is a good idea to pre-drill the holes that you intend to nail through. Drilling through the wood first will help prevent the wood from chipping or splitting when you nail it in later.
Tip 4 - Check Your Progress as You Go
When you place a new piece of wood trim on your window, only nail it in with 1 or 2 nails, then step back to look at your work. Sometimes it is easy to make mistakes and not notice them until you have to start all over, but if you take your time and check your work after only nailing in a couple nails, you can easily start over without a lot of hassle.
Tip 5 - Stain or Paint Your Wood before Installation
If you decide that you want to paint or stain your wood trim, make sure you do it before you install it. This makes it easier for you to cover all the areas while not making a mess or accidentally painting your walls or window. Make clean-up even easier by laying down newspapers at the beginning to collect any drips or smears from the brushes.
Tip 6 - Check Your Work Twice
It is always important to re-check your work. Measure everything twice, do a double coat of paint or stain and make sure things are installed correctly. Doing these steps will save you a lot of time and frustration in repair work.
