Login Error
Close
6 Tips for Repairing Broken Halogen Light Fixtures
by DoItYourself Staff
Halogen light fixtures feature an incandescent bulb that has been designed to operate efficiently over a longer amount of time than traditional light bulbs. They are used in many applications from table lamps to overhead lighting to headlights on automobiles.
Repairing your broken halogen light fixture such as a lamp can be simple by using the following tips.
Tip 1: Use Caution
A halogen lamp can operate at a temperature of up to 1000 degrees F. Burns can happen quickly and be severe. Make sure to unplug and allow the lamp to cool prior to troubleshooting.
Tip 2: Identify the Problem
Several factors can cause a halogen light fixture to not function. First check if the bulb is burnt out. When checking the bulb, do not handle it with your hands. Oils from your skin can cause the lamp to fail, so you will need to use gloves or a cloth to handle the bulb.
If the halogen bulb is not the problem, consider the bulb socket. The socket can be oxidized, corroded or burned which can prevent electrical connection with the bulb.
Other problems can include an overheated transformer, a broken or disconnected switch or an electrical short in the wiring.
Tip 3: Socket Repairs
Problems found with the socket can be fixed by gently scraping the electrical contacts until any corrosion or oxidation is removed and the shiny metal beneath is visible.
Check that the socket attachments to the lamp are not loose. If they need to be tightened, gently squeeze them together by using needle nose pliers.
Replace the bulb and plug the lamp back in to check if your repairs have fixed the problem. If the socket was too corroded, you may need to replace the socket entirely.
Tip 4: Check the Wiring
Once socket problems have been ruled out, check the fixture’s wiring. You can remove the base of the light fixture with a screwdriver to access the wiring compartment. Some bases may also open similarly to a battery compartment.
Once the base is removed, you will see the transformer, control switch and the power cord. Check for any broken, burnt or loose wires. If those are not readily visible, you can use a multimeter to test the wiring voltage and continuity or flow of electricity to the unit.
Repairs to wiring can be done by using a smoldering iron or a splicer to reconnect or improve the electrical connection in the fixture.
Tip 5: Check the Transformer
Using a VOM (Volt-Ohm-Milliammeter), you can measure the transformer output. This requires plugging the lamp in to measure the voltage. Typical output is about 12 volts and input is 120 volts. Higher or lower readings may indicate a bad transformer.
Tip 6: Use Proper Replacement Parts
Determine the replacement parts needed to make your repairs. Make sure to find the right parts for your halogen light fixture. Incorrect or incompatible parts may permanently damage the fixture.
Transformers, wiring tools and bulb sockets can be found at local electrical supply and home improvement stores.
 forum activity
