6 Tips for Wax Removal from Clothes
Wax removal can be one of the more difficult laundry tasks. Here are some tips you can try in order to remove wax stains from your clothes.
Scrape the Wax
You attempt wax removal from clothes, or any other cloth or fabric, by scraping the wax away by means of a sharp instrument, such as a knife or a razor blade. For this method to work, the wax should be dry by now and have become rather solid. When you work, be careful not to damage the fabric underneath.
Heat with an Iron
After scraping away as much wax as possible, you can iron the affected part. You should iron the garment from the underside and place an absorbent paper towel underneath the garment. The heat from the iron should melt away the wax residue, which should then be absorbed by the paper towel. To avoid any wax sticking to the iron’s base, you should also place a towel or a piece of cloth on top of the garment.
You should try to press the iron slightly and use as much heat as the garment can tolerate without sustaining any damage.
Heat With a Hair Dryer
You could also use a hair dryer to heat the wax stain. In the process of wax removal, pat the fabric softly with a paper napkin to remove as much wax as possible from the cloth.
Use Ice
You can also attempt cold wax removal. Place an ice bag over the stain. The freezing effect will help the wax to set and solidify. Then you may be able to remove it from the fabric more easily.
Apply Rubbing Alcohol
Another ingredient which is known to help in wax removal is alcohol. Rub it onto the stained part, with the intention to combat any dye marks that may be caused by the wax deposit. Gently dab the stained area with a towel and then sponge it down with some water. Make sure to dry it soon afterward.
Wait
Always keep in mind that, contrary to other stains which you should try to remove immediately, wax should settle and harden before you attempt to remove it. It is easier to remove wax when it has solidified. Plus you can achieve better cleaning results.
