7 Advantages of a Natural Gas Oven
A natural gas oven is a suitable alternative to the electric oven. Fueled by natural gas, or propane, a gas oven is the way to go for those who want a clean and affordable choice in cooking. Gas ovens have long been used in commercial settings. However, the benefits of gas make it an attractive choice for oven usage to homeowners. Below are 7 advantages you may want to consider.
Increased Cooking Control
A gas oven gives you greater control over your cooking temperature. Warm-up time is less with gas. Once you turn off the oven, cooking stops almost immediately. The instant on-off feature with gas cooking gives you complete freedom in good cooking. With electricity you need to allow some time for the oven to cool down. Some dishes may be affected by the prolonged high temperatures. Natural gas also cooks food more evenly than electricity. Gas ovens will give you better results in cooking.
Moist Cooking
Oven cooked dishes turn out better with natural gas. It does not dry the dishes because it allows a moist cooking environment. Foods bakes in a natural gas oven turn out perfect. Electric ovens frequently dry food.
Energy Efficient
A gas oven heats up and cools down faster than an electric oven. Warming begins as soon as you turn on the gas. Equally, cooking will stop just as soon as the gas is turned off. Far less energy is consumed in the on-off process unlike an electric oven. You need to allow the electric coils in the oven to heat up sufficiently before cooking actually begins. When turned off, the electric oven will take a while before it cools. Yet the energy in motion isn’t quite being used effectively. This makes a gas oven a better choice in terms of energy efficiency.
Lower Running Costs
Natural gas costs less than electricity. If you do a lot of baking, an oven fueled by natural gas may make a better choice for you. Overall, you are bound to meet higher costs on electricity bills with an electric oven, which utilizes more energy to operate.
Low Maintenance
Most gas appliances have low maintenance. Electric ovens usually have more frequent maintenance needs. Replacement of faulty oven parts becomes necessary more often with electric than gas ovens. This allows you to cut down on overall home maintenance costs.
Durable
Gas ovens have a longer life span than electric ovens. Frequent power outages can affect certain parts of your electric oven. The coils also tend to wear out with time. Wear and tear is quicker if the oven is heavily used. However, once you buy a gas oven and set up your gas supply, you’ve pretty much made a lifetime investment.
Dependable
A power outage can ruin your meal preparation when using an electric oven. With gas, you need not be worried about outages, effects of bad weather, or energy supply. Once a gas line is installed, it is always available whenever turned on.
