7 Advantages of Using a Digital Light Meter
A digital light meter is a tool which assesses how much light there is surrounding an item or area which is to be photographed or videoed. Digital light meters are generally used for photographic purposes or for film studios and can be highly useful for calibrating the aperture needed for a specific shot.
1 - Still Photography
Using a digital light meter for still photography is highly recommended as a form of assessing how to compose your photograph. If you are taking portraits of people or objects, you will not want your photographs to be too dark or too light. Employing the use of a light meter with give you a good sense of how much aperture to use in your picture or how bright the flash should be. Professional photographers all use light meters to determine the quality of light in the area.
2 – Filming
Film studios rely heavily on light meters to get the right atmosphere for a scene they are filming. They use reflective light meters to ascertain how much reflectivity is coming from the source and an incident light meter to assess how much light falling into the source from other influences, such as spot lights. This helps to avoid the chances of over exposure.
3 – Outside
For outside filming or photography, a digital light meter is good for determining the surrounding light. Natural light is completely different to artificial studio or indoor light, and it has natural shadows which form around and on objects. Always take a reading close to the subject as well as far away, to get a true reading. A digital light meters is far more accurate in assessing the light reading and will offer a more clear figure and calculation.
4 – Color
Some digital light meters allow you to calculate the ambient light and colors in the room or studio. It helps with shutter speeds and flash synchronizing and helps to create a far superior photograph or film shoot. Color monitors can assess light filtration and ambient changes.
5 – Spot Meters
These meter are ideal for measuring distant objects and subjects. You can assess backlight, or reflective surfaces and brightness ranges. They are mainly of use when incident meters cannot be used. They can be held up close to the object or subject to produce a clear reading of spotting light and small capsules of light from outer sources.
6 – Backlighting
Some cameras have in built back lights which can automatically adjust the exposure to take a better photograph. Not all cameras have this facility, so using a digital light meter will allow you to adjust the camera settings to gain the best advantage when taking a photo in bright or subdued light. The digital light meter will have a large LCD screen which will indicate the accurate reading and details of the subject.
7 – Consistency
Digital light meters offer you the benefits of consistently good photographic exposure. They help you maintain an equilibrium in your photographic composure and assist in preventing over exposure or dark photographs.
