Login Error
Close
7 Advantages of Using a Fiber Optic Cable Connector
by DoItYourself Staff
Everyone’s heard that fiber optic cable connectors are the wave of the future, but most people are not quite sure why. These tiny strands of light are changing telecommunications in many ways, rendering old copper wires obsolete.
Here are the advantages to using fiber optics:
1 - Heavy Metal
As opposed to bulky copper wires, fiber optics are about as thick as a strand of hair. This opens up the possibilities of how they get to your home. They are light enough to tie right into the lines that already run into your house, or can be run underground without requiring as much space. They are also able to be bundled in higher quantities than copper wires, which means more signal for less weight.
2 - Cheaper by the Dozen
Not only are fiber optics lighter, they are also less expensive to produce. Several miles of fiber optic cables can be made and run for less than it’s copper equivalent. That means your cable provider saves money given you more options.
3 - Clear Cables, Clear Signal
Fiber optics transmit faster and cleaner than copper. They also transmit more and are resistant to interference. A phone call or a television show will display an obvious improvement in clarity when using fiber optics, and because the flow is so much faster, internet usage is a breeze. There is no waiting for pages to load with the constant movement of fiber optics.
4 – Safety Reasons
Fiber optics are non-flammable. Using light instead of electricity makes them a source of power that you never have to concern yourself about.
5 – More Options for Less
Multiple phone lines and more television stations are much easier to maintain with fiber optic cables because of their size. With older cables, this meant a lot of wiring, but fiber optics can all fit into one thin wire.
6 – Flexible Options
Fiber optical cables are also very flexible. While copper cables would snap and break if pushed too far, fiber optics are more resistant to damage and easier to maneuver through out your home.
7 – Low Power Light
Energy efficiency is yet another advantage to fiber optic cables. They use significantly less power than other cable connectors. This means you save on your energy bills and your provider saves on theirs. Since the cost is less for your provider, the service is also less for you.
With all the advantages to fiber optic cables, it’s easy to understand the push everyone is making to switch over to them. They allow you more freedom, more options, and much better quality. They are better for the environment because they use less energy and do not require as much space to install. Best of all, they cost less to have and make more!
If you are considering switching your cable connector, look into fiber optics. They will be a good investment in your telecommunication future and the future of the planet.
 forum activity
